Old 22nd January 2020, 01:53 PM   #841
Ro808 is offline Ro808  Netherlands
Originally Posted by mabat View Post
You are free to try: Acoustic Horn Design The Easy Way (Ath4)
(it was 1.4")
This will have to wait until I get home.
Old 22nd January 2020, 02:19 PM   #842
pelanj is online now pelanj  Czech Republic
Ok, large waveguide like this needs some optimization in the script. It is running already for almost three hours All I would be interested in is the 20 - 2000 Hz range max. So I tried to change some parameters and will see.
Old 22nd January 2020, 02:30 PM   #843
mabat is offline mabat  Czech Republic
mabat's Avatar
Sure, you can change that in the script or in the "solving.txt" in the generated ABEC project - frequency range, number of points and mesh resolution. And of course you can also reduce the basic mesh fidelity directly via Mesh.* parameters.
Remember that this will be only a crude approximation where a rigid flat disc is still assumed as the source.
www.at-horns.eu
Old 22nd January 2020, 04:29 PM   #844
mabat's Avatar
Superformula!
OK, now the fun may begin. So far the only shape-curve (see the documentation) available was a superellipse. From now on it is possible to define a superformula (see wikipedia).
See also Example 22 | Superformula Shape | Super-formula Plotter for examples of various shapes - you will need to understand this.
The definition in the script file looks like this (the numbers for SF are: a, b, m, n1, n2, n3):
ShapeCurve = SF
SF = 2,1,4,8,12,12
SF.Rot = 0
The absolute size of the shape-curve is computed from Coverage_Horizontal and Depth.ConicSectionPart. This sets the width of the shape curve which is scaled so that just fits this dimension. Parameter SF.Rot gives an arbitrary rotation of the mouth if needed. Attached are two demo scripts. The only limitation for now is that for ABEC simulation you need quarter-space symmetry. I yet have to implement full mesh export (and it will take a heck of a time to run those sims). Eventually you can still use the "raw2rect" parameter to make the mouth rectangular (and force the symmetry where it makes sense).
The download: www.at-horns.eu/release/ath-4.4.1.zip
www.at-horns.eu
Old 22nd January 2020, 04:42 PM   #845
mabat's Avatar
Enjoy!
www.at-horns.eu
Old 22nd January 2020, 04:53 PM   #846
mabat's Avatar
Just a picture taken from wikipedia to give you some basic guide for the SF numbers (m, n1, n2, n3). With a, b you basically set the width/height ratio here, not the absolute size (as explained above).
I imagine the second shape will be the most useful.
www.at-horns.eu
Old 22nd January 2020, 05:14 PM   #847
mabat's Avatar
I quickly tested the sf1 (demo), it's really nothing special -
www.at-horns.eu
Old 22nd January 2020, 06:03 PM   #848
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
With these "DNA" arrays that I like to build, the reason that they work is basically because they're asymmetrical on the X and the Y axis.
IE, in a conventional D'Appolito array, there will be off-axis nulls at predictable frequencies, and the nulls are caused by pathlength differences. In particular, when the pathlength of two woofers is 180 degrees out of phase, you get a deep null.
So, the DNA array is an elegant solution: NONE of the drivers share the same X or Y axis, hence the smoother response.
But once all of that made sense, it hit me that another way to implement the DNA array would be to simply use an odd number of drivers in a ring. Five drivers in particular is an attractive number. It allows for spacing that's nearly as tight as four, and no driver shares the same X or Y axis. But it requires an oddly shaped waveguide...
Old 22nd January 2020, 06:07 PM   #849
mabat's Avatar
Piece of cake now
I'm only a bit sceptical about the result. Well, I may be surprised.
www.at-horns.eu
Old 22nd January 2020, 06:32 PM   #850
This site allows you to visualize what tweaking the paramets does, in real time:
http://benjaminbojko.com/work/showca...s/supershapes/
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
