Thread Tools
Old 30th July 2021, 03:45 PM   #7501
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by mabat View Post
That's just tied to the amplitude response, i.e. there's simply a resonance somewhere inside the driver.
That's the diaphragm resonance - surprisingly low damping for a compression driver.
Earl Geddes Gedlee Website
Old 30th July 2021, 03:54 PM   #7502
mabat is offline mabat  Czech Republic
mabat's Avatar
Oh, I see. BTW, this is the throat impedance of the WG used. So is there a chance that in a waveguide that has a higher throat impedance to a lower frequency, the dip between 1 - 2 kHz won't be as pronounced?
-swg33-throat-impedance-png
https://at-horns.eu
Old 30th July 2021, 04:18 PM   #7503
ErnieM is offline ErnieM  United States
Here's another measurement of the HF1440 I forgot about.
HF1440 New Ring Compression Driver from Faital Pro.
Old 30th July 2021, 04:22 PM   #7504
mabat's Avatar
Thanks. So we want a horn with throat impedance peaking just above the fundamental driver resonance, don't we. Damn, this calls for a lumped-element model of the driver.
https://at-horns.eu
Old 30th July 2021, 07:33 PM   #7505
gedlee's Avatar
AS you might expect, the coupling of the elements around resonance can get complex and unintuitive. Models are usually required.
But at these L(ish)Fs the waveguides impedance looks like a simple mass. The dual humps in the electrical impedance curve are due to the coupled oscillator defined by the gap compliance and the two masses - waveguide and diaphragm. At the lower impedance you have the two masses in phase and the above peak they are out of phase, i.e. 180 degree phase shift. This coupling makes the whole problem much more complex.
Old 30th July 2021, 10:03 PM   #7506
Zvu is offline Zvu  Serbia
Zvu's Avatar
This evening my friend Jokerbre and i measured Peerless DFM2535R00-08 on Mabat's ST260 waveguide.
Measurements are done from 1m distance with calibrated Behringer ECM8000, Steinberg UR12 and gate frequency of 4.4ms so enough to capture trends of this waveguide. What is shown here are measurents 0-90 degrees with ≈7.5 deg increments in between. Since i did not calibrate REW and my mic for loudness, SPL levels shown aren't representative of actual SPL level. Off axis measurements 60 degrees and up are smoothed 1/48 to avoid "hair" at higher frequencies.
0-90 degrees
0-45 degress
45-90 degrees
75dB vs 85dB loudness
measurement on axis (red) and averaged 0-90 degrees (purple)
printed waveguide
I must say that i've never seen better and more extended frequency response from a smaller waveguide and a cheaper compression driver.
Tesla; George Carlin
Old 30th July 2021, 10:07 PM   #7507
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
Nice!
Old 30th July 2021, 10:22 PM   #7508
Kevmoso is offline Kevmoso  United States
Very nice indeed. Nice looking print quality as well.
Same quality of directivity results I measured with a different driver, BMS 4552nd. ST260 is a killer little waveguide.
Such good directivity I am left wondering what would be a good match below.
Side by side 8s and a 15 below is one thought.
Old 30th July 2021, 10:30 PM   #7509
Zvu's Avatar
I have a pair of FaitalPro 12pr320-8 i must spend somehow.
0.2mm nozzle with 20% infill.
Old 30th July 2021, 11:12 PM   #7510
A 12" is "the other" option I have considered but I always like to complicate things for myself... That 12pr320 you have is a nice nice NICE option!
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
