Thread Tools
Old 24th March 2021, 07:41 AM   #6501
mabat is offline mabat  Czech Republic
mabat's Avatar
The wobble is definitely a resonance - stored energy, not a reflection or diffraction. You can recognize resonance by a constant oscillation period in the impulse response. The other effects don't behave like that.
https://at-horns.eu
Old 24th March 2021, 08:29 AM   #6502
aragorus is offline aragorus  Denmark
Originally Posted by fluid View Post
Looks like the polarity is inverted somewhere in the chain, on a single driver in phase the peak should go up first
It's just 1 mic and 1 CD
Old 24th March 2021, 08:34 AM   #6503
mabat's Avatar
Invert polarity on the driver
https://at-horns.eu
Old 24th March 2021, 08:35 AM   #6504
Could be the 3d print resonates
I'll try to hit it with something and record to see if it resonates
Old 24th March 2021, 08:40 AM   #6505
mabat's Avatar
Based on the IR plot it's a resonance around 17 - 18 kHz, it's hardly the waveguide. It comes from the driver, IMHO.
If you correct this with a simple passive RLC (or a DSP biquad, doesn't matter) you should get rid of it to a large degree. (I'm not sure I would bother this high in frequency but you can always test audibility of this easily.)
https://at-horns.eu
Old 24th March 2021, 09:21 AM   #6506
mabat's Avatar
For the next release of Ath I implemented a new parameter/feature: Slot.Length
It basically adds a flat segment before the actual OS-SE profile, of which the length can be continuously variable (along with all the other parameters). It will be fun watchig what people come up with
https://at-horns.eu
Old 24th March 2021, 09:45 AM   #6507
fluid is offline fluid  Australia
That makes sense as the BMS4550 has a pretty nasty breakup at 18K, there looked to be diffractive ripple in the FR which is what my comment was based on.
Old 24th March 2021, 09:50 AM   #6508
camplo is offline camplo
Wow! and I agree....I was just swallowing Patricks post and staring at my 2380a lol....I wrote a response and had to delete it cause it finally sank in lol... thinking about the discussions surrounding the 2380a I've had in the past...the idea of its error in technicality (dispersions slots and distortion) combined with the 2382a being used on the Strauss mastering monitor...for home spl levels...maybe there is some potential to combine loading and constant directivity that we have left on the table? Especially after cleaning up the sharp edges.
I envision a focus on slot modelling as a separate discussion from the rest of the horn flair? In that maybe one could take an ideal constant directivity slot and add it to a number if different flare profiles...
One thing to take into account is the idea that with this 2380a the exits area is 3.1416"...an somewhat rough measurement of the slots ending shows the CSA to be ~4.25 (1" wide and 4.25" tall) and with a 4.5inch dept....its sorta like a truncated horn .....that has a very narrow width, thus losing direcivity on the horizontal plane (at HF)...into... another horn/waveguide profile, to help clean things up...at least thats how I see it...
Old 24th March 2021, 09:53 AM   #6509
mabat's Avatar
Frankly, I don't believe it will happen. I also don't quite agree with what Patrick Bateman wrote above.
https://at-horns.eu
Old 24th March 2021, 10:04 AM   #6510
mabat's Avatar
Attached is a STL file for an extremely simple example -
Throat.Diameter = 36
Length = 200
Coverage.Angle = 45 + (14-45)*sin(p)^2
OS.k = 1 + (2.2-1)*sin(p)^2
Slot.Length = 60 + (2-60)*sin(p)^2
https://at-horns.eu
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
