Acoustic Horn Design – The Easy Way (Ath4)
The latest developmnet in the petal construction -
Reactions: 4 users
Hi all,
I've seen few projects using a TC9FD18 with a WG. I thought I would have a go too!
I'm trying my first "whole cabinet" print (50hrs) on a Phrozen Mega 8k. The band at the top is due to vacuum pulling up the liquid within that part of the cabinet. I should have put a tiny 1mm hole at the very apex to prevent this suction/deformation. Quarter symmetry report attached.
I took a wild guess at 30deg exit angle :unsure:
I may delve into complex sources....
Reactions: 1 user
Try SuperPP resin from 3Dmaterials. It's like polypropylene, good damping. Use flexible build plate. Warping can be an issue with resin printers, especially thin walls like this if you like to use multiple driver plates: (that's why there are rigid resins with ceramics)
Dyes used for casting epoxy should work and give you nice transparent waveguides.
Reactions: 1 user
I'm talking about SLA - much better surface and speed with fast resins but more likely to deform. That's why you print throat at once and do petals at some distance. Casting epoxy isn't cheaper than UV resin only cheapest polyester that smell awfully. Those who have SLA LCD printer please write here if you prefer rigid resin with microbaloons or PP like? Standard resins (cheapest) is too brittle.
Casting polyurethane is less than 15 €/kg, FDM filament around 18€/kg. For a pair of 15" waveguides I need ~1.4 kg of filament and around 1.2 kg of the filler, that makes around 45 €. I don't believe switching to SLA could be cheaper or any better in the end (not counting a large-format SLA printer).
How do you finish the surface of SLA prints?
BTW, I've just filled one petal with the polyurethane (Dawex GAFORM R55 - a local product). It runs through even the denser infill smoothly. Temperature - if left in the cup it reaches almost 70°C. When poured into the petal I measured around 45°C peak - not an issue. There's also a slower version (GAFORM D500), that would be even less warm but it's not needed, 50°C is still safe. Perhaps if I wanted the fill also the throat part, I would need the slower one.
Acoustically, it's pretty much dead now, overall I'm really pleased with the result.
Reactions: 1 user
