Thread Tools
Old 23rd January 2021, 04:44 AM   #5101
mabat is offline mabat  Czech Republic
mabat's Avatar
BTW, to view a pressure field, simply add this to the "observation.txt" file:
Code:
Nodes "FieldNodes"
  Scale=1m
  1  -0.2 0.3
  2  0.4 0.3
Field "F1"
  RefNodes="FieldNodes"
  EdgeLength=10mm
  BodeType=LeveldB; StepSize=3
  Range=60
  1 1 2
You will probably want to reduce the number of frequencies however, otherwise it will take quite a long time.
To see the throat in detail you can easily increase the resolution and limit the field area:
Code:
Nodes "FieldNodes"
  Scale=1m
  1  0.0 0.2
  2  0.15 0.2
Field "F1"
  EdgeLength=3mm
  Range=60
  1 1 2
https://at-horns.eu
Old 23rd January 2021, 04:59 AM   #5102
mabat's Avatar
I just realized there are several options for the field type (BodeType):
"LeveldB, Ampl, Real, Imag, Phase, LeveldB_Phase, Ampl_Phase, Complex"
I've never experimented with this. Maybe it could show something interesting.
https://at-horns.eu
Old 23rd January 2021, 12:41 PM   #5103
Arnandsway is offline Arnandsway  Netherlands
Originally Posted by mabat View Post
As some start to print and measure the ST260, maybe it's useful to collect (again) the results so far - this is a courtesy of Pet007 who measured virtually the same WG before (maybe there was a tiny difference, I don't really remember), with three different drivers -
Just a note - the DI as shown is calculated from the front polars only (the only measured). The "real" DI will be closer to the simulations, where it is full-space.
What crossover frequency would one want to use with this WG? My guess would be around 1200 hz to keep a smooth DI?
Old 23rd January 2021, 12:59 PM   #5104
mabat's Avatar
This depends mainly on the compression driver used - what it can handle. Generally you want the lowest XO frequency possible with what you have. Then you simply choose a woofer size that makes a smooth overall DI. If we assume that most of the 1" drivers can handle 900 - 1000 Hz with ease, what should be the right woofer size for this, looking at the DI around this frequency (around 7 dB)? I don't know off the top of my head - maybe 12", maybe 10"... There is some freedom anyway.
https://at-horns.eu
Old 23rd January 2021, 04:36 PM   #5105
JSS is offline JSS  Canada
Now it would be great to have this measued to see if it's real to that extent. If it was, the whole system would "ring", i.e. there would be strong peak(s) in the frequency response and accompanying ringing in the time domain. Correctable with EQ but somewhat troublesome. What's interesting is that it has virtually no effect on radiation pattern.
I'll print and measure to see if it's a real problem and report back. It's printing now hopefully it doesn't crap out. It's 9hrs to print half. Hoping to have something to report soon...
Old 23rd January 2021, 05:17 PM   #5106
This is what I get from a simulation in Vituixcad. I simulated the diffraction-response from two 8" woofers on a 25x90 cm baffle. I SPl-traced the measurements of the ST260 + B&C DE502. And then I did some EQ'ing to get the responses flat.
Crossover is at 1000 hz LR4, this gave the smoothest DI. Note that the SPL-traced tweeter response only goes to 90 degrees, while the diffraction simulation goes 360 degrees.
Here is the dashboard from Vituixcad and below that the diffraction-tool.
Old 23rd January 2021, 09:29 PM   #5107
jzagaja is offline jzagaja  Poland
Anyone tested low resonance hard rubber material (Shore D 65) vs high resonance standard PLA/ABS or with fibers 25mm thick with low infill? I mean SPL difference at 100dB if any or subjective observations? Augerpro?
email me jzagaja at gmail
Old 24th January 2021, 06:36 AM   #5108
mabat's Avatar
I'm holding my breath...
https://at-horns.eu
Old 24th January 2021, 05:17 PM   #5109
Ok you can breathe now The print split in the middle of the round over. So I'm thinking of making it thicker there and print with higher temp. See how it goes...
I'm new to 3d printing, if you guys have suggestions, please feel free.
It's been frustrating but fun at the same time lol
Old 24th January 2021, 05:26 PM   #5110
mabat's Avatar
Aww, I feel your pain. I'm not an expert either.
https://at-horns.eu
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
