Thread Tools
Old 22nd January 2021, 06:46 AM   #5071
mabat is offline mabat  Czech Republic
mabat's Avatar
Originally Posted by jcarothers View Post
Sure, attached.
I've figured that out. The workaround at the moment is to not let q = 1, but always slightly smaller (0.995 is fine).
https://at-horns.eu
Old 22nd January 2021, 07:02 AM   #5072
Brinkman is offline Brinkman  United States
Originally Posted by Patrick Bateman View Post
One time when I lived in Oregon City, I did a sine sweep into a B&C woofer, didn't check the voltage level, and I think they literally heard it the next town over. It's a straight shot across the river and there's nothing to attenuate the sound between the two towns. People probably thought it was a Tsunami siren.
I’m sure the comfortable folks in West Linn are used to much worse from across the river. You should see OC now... but I digress off topic
Old 22nd January 2021, 08:22 AM   #5073
kessito is offline kessito  Netherlands
Originally Posted by mark100 View Post
Technically, I've been taught that nothing is as accurate as sine sweeps.
But that is soooooooo much technicality, and not the least to do with anything that matters real world.
But even technically, another great thing about dual-channel using pink or music or whatever, is that it allows real-time temporal averaging, increasing accuracy beyond that of a single sine sweep.
But that said, you could average multiple sine sweeps as REW explains, and maybe achieve even greater technical excellence ....
And make everybody, including ourselves, even more ultra annoyed !!! LoL
Angelo Farina, the author of the ecponential sweep method, has shown that the best, most accurate, result is when you use one really long sweep instead of averaging.
( which is of course even more annoying, I know )
Old 22nd January 2021, 09:25 AM   #5074
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Interesting! I'll need to try that out.
(Original post said "I'll need to increase my length" and I realized that was NSFW)
Old 22nd January 2021, 09:26 AM   #5075
Ha! That's exactly the town I was talking about. Right across the river.
Old 22nd January 2021, 10:18 AM   #5076
fluid is offline fluid  Australia
I'm having a bit of trouble getting the reports to work, seems like it might be due to my file structure but I can't quite work out what I'm doing wrong, any ideas?
-ath-error-jpg
Old 22nd January 2021, 10:29 AM   #5077
miero is offline miero  Czech Republic
fluid, try to remove whitespace from the directory name "ATH FILES"
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 22nd January 2021, 10:29 AM   #5078
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
Hi, you've got space in the directory name which ruins the command. It just renamed my problematic folder, couldn't figure out other way around
Old 22nd January 2021, 10:45 AM   #5079
You were both right, now it is working Needed to make a new directory structure for 4.7 otherwise my old files would complain about being in the wrong place.
Old 22nd January 2021, 10:50 AM   #5080
mabat's Avatar
You are the first one!
https://at-horns.eu
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
