Thread Tools
Old 21st January 2021, 04:10 PM   #5051
mabat is offline mabat  Czech Republic
mabat's Avatar
I've never seen that. Could you send me the whole file?
https://at-horns.eu
Old 21st January 2021, 04:16 PM   #5052
jcarothers is offline jcarothers
Sure, attached.
Old 21st January 2021, 04:23 PM   #5053
mabat's Avatar
I'll check that later, just one thing I see right now - be sure to add "Source.Velocity = 2", otherwise you model quite a different thing:
https://at-horns.eu
Old 21st January 2021, 04:26 PM   #5054
mabat's Avatar
You need this:
-axial_driving-png
https://at-horns.eu
Old 21st January 2021, 04:31 PM   #5055
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by Dkalsi View Post
Lastly - and I know this is going to sound ridiculous - but I'm going to add that even the frequency sweeps used to measure the horn sounded quite pleasing. I hate taking the measurements, especially of compression drivers. But I've taken measurements of the drivers on QSC clone waveguide, SEOS waveguide, and the Wayne Pi waveguides - and this horn was the most bearable of them all. Anyways ---- let's get back to objective data :-).
I've probably done a thousand measurements of various projects. And the moment I hear that pink noise sweep, I know if it's good or not.
It's such a bummer when I work on something all weekend, do that first measurement in REW, and before the measurement even appears on screen, you can tell if it's good just by the sound of the sweep.
Old 21st January 2021, 06:53 PM   #5056
Dkalsi is offline Dkalsi  United States
Default Additional Measurements
Here are additional normalized measurements (to isolate horn performance), with a slightly better-printed horn (same Peerless driver).
Old 21st January 2021, 07:02 PM   #5057
mabat's Avatar
Thanks again. I think that better would be to normalize to 10. If you look at the sim (#4969), just above 5 kHz there is a slight ripple on-axis. If normalized to 0 this ripple will show in all the other polars instead - that's not describing the overall behaviour very well. I know it's always difficult with normalization. Maybe you could simply show the raw data as well.
https://at-horns.eu
Old 21st January 2021, 07:33 PM   #5058
Default Normalized to 10 and raw
Sure, Matab.
See additional pics. Now normalized to 10 degrees, and raw.
Again - the two sides have not yet be glued - just taped together.
Old 21st January 2021, 07:37 PM   #5059
mabat's Avatar
Great. Do you know the details of the exit section of the driver used (angle and depth of the last conical section)?
https://at-horns.eu
Old 21st January 2021, 07:50 PM   #5060
JSS is offline JSS  Canada
I'm ready to print the ST260, just want to make sure. Is 30% infill good enough?
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
