Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
#4841 | |
They told me they need at least 10 - 12 mm for a part like this not to break during manipulation (to be sure it doesn't).
https://at-horns.eu Last edited by mabat; 13th January 2021 at 06:29 PM. |
#4842 |
On the website of the snail enclosure speakers it is stated that they finish with a special layer because else the material is too brittle, are you aware of this? And have you gotten info from the manufacturing company about the possibillities to make the material less brittle?
I can imagine that some sort of epoxy coating could be applied, maybe sprayed on. |
#4843 |
Sure, as I already said, it will be impregnated with epoxy resin. They said it's like stone then. Only during the initial manipulation it may be prone to breaking if too thin.
https://at-horns.eu |
#4844 |
Ah sorry, missed that info , thanks, looking forward to the results!
#4845 |
It's a little hard to see - on one picture it looks like its "filled" - like if you would place it with the mouth down on a table and fill water in it to become like a ring shaped pond.
But maybe its 12 mm everywhere? //
More distortion to the people! Timing . . . . is paramount. |
#4846 |
Yes, that's how it is - "filled". It may be more than 30 mm on average as it is now.
#4847 |
OK!
So gedlee, do we need to polish the inside of a horn/wg or it will sound "course"...? //
#4848 |
... (yeah, it's a bit hard to see)
#4849 |
![]() glossy, glossy ![]() //
#4850 |
I believe it could be made glossy
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Easy horn (Eazy Horn) still work? Alternatives? | Soldermizer | Subwoofers | 2 | 4th March 2014 06:01 PM |
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator | Tazzz | Swap Meet | 8 | 3rd November 2012 09:00 AM |
easy exponential horn speakers anyone? | 12345chris | Full Range | 9 | 21st March 2012 12:32 PM |
Easy horn, quadrant horn? | Hentai | Multi-Way | 2 | 29th January 2012 09:50 AM |
An easy to build classic horn? | dabbler | Multi-Way | 22 | 1st September 2011 09:01 AM |
New To Site? | Need Help? |
