Old Today, 06:46 AM   #3281
mabat is offline mabat  Czech Republic
The polars for s=0.5:
-os-term-pol-png
www.at-horns.eu
Old Today, 07:25 AM   #3282
Ro808 is offline Ro808  Netherlands
Demo11 with length = 180 mm
Old Today, 09:32 AM   #3283
fluid is offline fluid  Australia
mabat, Autodesk has just reduced the functionality of the free version of Fusion 360, the main sticking point being that step export is no longer allowed. This would make it hard to transfer between packages or give a file to a CNC shop. It certainly is a pain for what I have been using it for lately.
How hard would it be to get the curve import going on another CAD program?
Old Today, 09:42 AM   #3284
Yeah, I've noticed that, a pity. I don't know, the best advice I can give you at the moment is to get everything done before 10/1
Probably some solution will emerge but right now I don't have a clue.
www.at-horns.eu
Old Today, 09:45 AM   #3285
Can you explain how the curve import works in Fusion? That might help to work out how to do it with other programs.
Old Today, 09:51 AM   #3286
First, it must be a free (or cheap) program, otherwise it makes a little sense. I'm not an experienced CAD user so I don't know much about the possibilities in this area. Scripting language (as with Fusion) would by nice but not really necesary I guess, as long as it is possible to create the shape manually. If you are interested how it's done in Fusion just see the import scripts - nothing more than the commands available are used there. Basically it imports the splines and then uses the loft feature.
www.at-horns.eu
Old Today, 09:55 AM   #3287
FreeCAD can be scripted through Python as it is built to do that, it's not as user friendly as Fusion 360 but being open source the same feature limitations won't happen
Old Today, 10:09 AM   #3288
This seems like it could work to create to create the curves from the points files if the data was changed to the right format?
Macro WireXYZ - FreeCAD Documentation
Old Today, 10:17 AM   #3289
Sure, I think you could try it right away - see the Output.Coords options.
www.at-horns.eu
Old Today, 11:17 AM   #3290
Is there a way to set a space as the delimiter? I've tried a few options and got nothing useful. I can set it to something else and change it with a text editor if needed.
  Reply to this post
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
