Old Today, 08:35 AM   #2721
mabat is offline mabat  Czech Republic
mabat's Avatar
Sorry, Kees, I don't buy it. This is even what Mr. Panzer recommends and also there's an example horn project utilizing this very method. And I really can't see how it could be wrong - technically. It's just a shape of the outer shell that is different.
www.at-horns.eu
Old Today, 09:03 AM   #2722
mabat's Avatar
The outer cylinder extended 5 mm past the throat, so the whole interior is now enclosed in the outer shell (however irrelevant that is) -
-105mm-polars-png
www.at-horns.eu
Old Today, 09:16 AM   #2723
mabat's Avatar
The raw mesh file -
www.at-horns.eu
Old Today, 09:53 AM   #2724
mabat's Avatar
My attempt to explain the worse behaviour for the longer tube is that due to the presence of the tube the SPL falls slower to the sides and as such there's a higher chance for the diffracted waves to noticeably interfere back.
www.at-horns.eu
Old Today, 10:01 AM   #2725
kessito is offline kessito  Netherlands
Thank you for trying!
I have to be honest; you have me in doubt now, I will do some of my own experiments once back home.
Another thing why I often try to not use subdomains in tjese cases; you will see that if you change the thickness of the domain coupler ( so not 5mm but ie 50mm in front of the mouth) the results change. I have never gotten a satisfactory answer from mr .Pfanzer about the optimum, I usually use 50mm if I have to because of many more subdomains.
You could als try not using subdomains at all, this gives the best matching results with reality in my experience.
Cheers
Old Today, 10:03 AM   #2726
One other obvious observation; of course this is , diffraction wise, the worst possible shape since all diffraction pathlengths are equal.
Old Today, 10:06 AM   #2727
mabat's Avatar
Well, I have found the subdomains to be pretty useful, they definitely work well fo me. Also notice that in this case the interface is just flat. The 5 mm is the depth of the physical body, not the interface.
www.at-horns.eu
Old Today, 10:08 AM   #2728
mabat's Avatar
Yeah, but if I make the tube very short (5 mm), i.e. the edge very "sharp", these problems just go away to a great extent (#2713) - that's what is interesting. I would expect it to be the other way around.
www.at-horns.eu
Old Today, 10:25 AM   #2729
wesayso is online now wesayso  Netherlands
wesayso's Avatar
Can you make it flat for 5mm and follow up conical back to the throat? Sort of a horn shape without going all out to follow the inner horn shape. If that works, following the true horn shape would also work out (or perform even better).
Use Science to design your speakers and they will sound like a piece of Art...
Old Today, 10:33 AM   #2730
mabat's Avatar
I will certainly implement several options for this shape, including the "real" one, as this is quite interesting.
www.at-horns.eu
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
