Old 20th September 2019, 05:48 PM   #221
mabat is offline mabat  Czech Republic
mabat's Avatar
A few pictures will tell more than a thousand words, I only have to code it first. Then I will show better what I mean.
Originally Posted by gedlee View Post
Don't the two curves have to match slope, not curvature? With slope only A works.
Actually it is easy to match both. The slope is allways matched by simply rotating the clothoid - it doesn't matter where it starts. Curvature increases linearly along its length so it's all about finding the right point.
www.at-horns.eu
Old 20th September 2019, 06:37 PM   #222
gedlee is offline gedlee  United States
gedlee's Avatar
Point "B", still seems wrong to me.
Earl Geddes Gedlee Website
Old 22nd September 2019, 06:38 AM   #223
norman bates is offline norman bates  United States
norman bates's Avatar
Mabat,
In post 212, you show a poorly terminated os (your pic below).
Is that poorly terminated because of the last bend to the mouth (baffle) ?
If so, what would a good os look like ?
I though os was conical, but with a rounded throat, then a round over at the mouth.
Couldn't tell you how fast it opens, just better dispersion for a wider mouth to distance to throat.
How to Reduce Diffraction on Your Conical Horn
Old 22nd September 2019, 06:34 PM   #224
mabat's Avatar
Yes, it's too small, too abrupt.
OS is not a cone with a rounded throat. It's hyperbola from the throat to infinity. Mouth termination is not part of OS and should be as smooth/gradual as possible - at least this is obvious from the calculations so far. It's a continuum, there's no dividing line between right and wrong, however.
www.at-horns.eu
Old 22nd September 2019, 06:38 PM   #225
mabat's Avatar
I've finally managed to figure out the one-describe-it-all equation, from throat to mouth.
Not there yet, but close...
(Black line is an OS connected to a clothoid, orange line is the new equation.)
www.at-horns.eu
Old 22nd September 2019, 06:56 PM   #226
mabat's Avatar
Closer still...
Not much of use I guess, but it's nice.
www.at-horns.eu
Old 22nd September 2019, 07:07 PM   #227
Ahhhhhh, thank you.
That makes sense.
Many os ive seen seem to have that last soft corner (mouth break ?).
I'd figured it was a place that could be improved.
Tricky where to deviate from conical, and how fast to do it.
Even my 2384 has a bit of bend in the path before the last mouth round over.
I bet it helps (conical slight bending).
Again, thank you.
Old 22nd September 2019, 07:25 PM   #228
gedlee's Avatar
That is exactly the kind of equation that I had in mind when I mentioned this before. Nice work.
Old 22nd September 2019, 07:34 PM   #229
mabat's Avatar
Yep, I know, thanks. I only have no idea how to calculate all the parameters based on desired horn dimensions. Right now it's only fitted to a particular sample - just a quick excercise. I also felt there must be an equation like this, maybe this is not even the best one...
Oh, and it actually should go like this -
www.at-horns.eu
Old 22nd September 2019, 08:02 PM   #230
gedlee's Avatar
Now that I think of it, it would have to be a two part equation. The first pure OS and then the OS plus equation, right? The joining point and the total length would set the values of the parameters.
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
