Old 11th September 2019, 02:51 PM   #181
superlian is offline superlian  Norway
What about a conical shape?
Old 11th September 2019, 03:24 PM   #182
mabat is offline mabat  Czech Republic
mabat's Avatar
Like this? Not good.
Old 11th September 2019, 08:39 PM   #183
natehansen66 is offline natehansen66  United States
Originally Posted by Patrick Bateman View Post
can you post "small.cfg" and I'll try it on my end?
I've attached the file - thanks.
mabat, this is a new 64bit machine.
Old 11th September 2019, 10:07 PM   #184
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
It works on my system, but here's some possibilities:
1) do you have gmsh-4.3.dll in your path? I have mine in the same directory as ath4.exe. When I deleted the dll I didn't get the same error as you, but close.
2) In your config file, please comment out the line "Out.DestDir"
The reason that you want to comment out that line is twofold. First, if you have a "D" drive, your user may not have permissions to write to the folder. Second, if you omit the folder, ath4 will create the folder for you.
Having said all that, I was able to run it fine on my side by commenting out that line.
Old 12th September 2019, 01:26 AM   #185
PB thanks for looking into that. I do have the correct gmesh dll in the same dir. I'll try changing the config file in the morning and see if that does it.
Old 12th September 2019, 04:42 AM   #186
mabat's Avatar
It might still be some unhandled exception in the progam. You can also try this: http://at-horns.eu/release/ath4_4.3.5.zip
Old 12th September 2019, 04:43 AM   #187
amthanhkhangphudat is offline amthanhkhangphudat  France
amthanhkhangphudat's Avatar
Thank you for answering what I'm always looking for, great.
#khangphudataudio - Khang Phu Dat Audio
Old 12th September 2019, 09:42 AM   #188
This still isn't working. Just to be clear that I'm doing this right I took a screen shot of my ath dir. For the shortcut right click desktop-create shortcut-search "cmd.exe"-right click properties-start in "D:\ath_release_4.3.4"
Open the new shortcut " ath4.exe examples\small.cfg"
Old 12th September 2019, 09:49 AM   #189
mabat's Avatar
Previously you attached a file "small.txt" - so you changed the file extension or what else is happening? It may be that the program can't open the file (i.e. the filename doesn't match) but I would excpect different message then. Hmm...this is strange. Hasn't the file been renamed by the text editor to "small.cfg.txt" or something?
Old 12th September 2019, 01:47 PM   #190
I changed the file extension because the forum wouldn't let me attach .cfg - I assume Patrick changed it back. I've been using the .cfg extension
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Copyright ©1999-2019 diyAudio
