Old 9th September 2019, 10:30 AM   #171
mabat is offline mabat  Czech Republic
mabat's Avatar
This is for the infinite baffle. I only changed frequency resolution parameters in "solving.txt":
Control_Solver
f1=800; f2=16000; NumFrequencies=40
Abscissa=log; Dim=3D; MeshFrequency=25000; Sym=xy
Old 10th September 2019, 06:25 AM   #172
superlian is offline superlian  Norway
Nice
What is the cutoff?
Autotechs Tractrix 1000 is 12 cm wide: TRACTRIX-1000 - Horns by Auto-Tech
And JMLC 2000 10 cm: http://horns-diy.pl/en/horns/jmlc/jmlc-2000/
I think it is better with a much smaller horn and a cutoff around 5000
Ale have very small horn: http://soundgate.net/product/NTE1.highend
Old 10th September 2019, 06:56 AM   #173
mabat's Avatar
There is no such thing here - you can see radiation impedance has no sudden drop, what's usually called cutoff. If I ever wanted to make a very small horn for 5 kHz xover (to a bigger midrage horn I suppose - not a very good idea, but OK), I would do it the way I showed, maybe a bit smaller, this was just a quick attempt. You can easily try it smaller and see what would you get - this is what the tool is for.
Old 10th September 2019, 07:05 PM   #174
454Casull is offline 454Casull  Canada
Great work! Really interesting stuff.
Old 11th September 2019, 01:09 AM   #175
natehansen66 is offline natehansen66  United States
I'm probably just a complete command line dunce but I can't get this to work. I've followed the guide and this thread afaik. Created ath in the suggested dir, created the shortcut as described, have the output in the config file pointing to a new dir as suggested, and have "open with" set to notpad for the config file but am getting this. What am I doing wrong?
Old 11th September 2019, 01:29 AM   #176
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
can you post "small.cfg" and I'll try it on my end?
Old 11th September 2019, 05:42 AM   #177
mabat's Avatar
Isn't that a 32bit PC? I think the program is compiled for 64bit by default. I will look how to compile for 32bit. Otherwise I have no idea.
Old 11th September 2019, 07:24 AM   #178
Is it possible to simulate the response of a routed waveguide lik Sagarmatha Duo from Bastanis have?
Products
On a 1 inch baffle with a 1 inch hole then routed with a R 1inch round edge router bit?
85434M | 3/4 In. x 1 In. Carbide Tipped Roundover Bit | Bosch Power Tools
Old 11th September 2019, 08:41 AM   #179
mabat's Avatar
It seems the program doesn't handle properly dimesions comparable to a throat diameter. I'll look at what the catch is. Anyway, this is the closest I could get. Besides the resonance (which is correctable in principle) it will beam at high frequencies. I'm not sure it's the right way to go...
- The program as it is now doesn't support radius as mouth termination.
Old 11th September 2019, 09:06 AM   #180
mabat's Avatar
Well, the beaming in this case is just a slightly worse than a typical 1" dome tweeter. Compression driver won't be as smooth but will have much higher efficiency. Maybe with some small driver like DE360 it could make a usable tweeter (instead of a 1" dome).
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Copyright ©1999-2019 diyAudio
