Old 1st September 2019, 01:49 PM   #161
mabat is offline mabat  Czech Republic
mabat's Avatar
That will be a big beast. For what driver?
Old 2nd September 2019, 03:29 AM   #162
ilardi is offline ilardi  United States
Default ath-4.3.4 No such file or directory
This looks like a wonderful program, but I am having a bit of trouble installing it.
I have installed ath4, including the .dll files ,changed the small.cfg file to find the right directory, etc. Whenever I run it, however, I get an error message of:
ath-4.3.4
(notice the hyphen, not an underscore). I've even tried adding such a directory in a few places, but to no avail. Is this directory hard coded into the code? I have no idea what I am doing wrong. Any help would be appreciated.
Terry
Old 2nd September 2019, 07:36 AM   #163
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
ath-4.3.4
Run it on the command line. "cmd.exe"
Old 2nd September 2019, 07:41 AM   #164
danibosn is offline danibosn  Croatia
not yet sure, some 1.4"or even BMS coaxial
Old 2nd September 2019, 11:45 AM   #165
mabat's Avatar
ilardi
Ahh, that may be tough to find out. Please try this temporary release, it should manage the output directory better: http://at-horns.eu/release/ath4_4.3.5.zip
(No new functionality there yet - still in progress.)
Old 6th September 2019, 03:02 AM   #166
Thanks. That worked. My CAD program weapon of choice is Freecad which was able to open the STL file without trouble although FreeCad doesn’t seem to support the .msh format.
Terry
Old 8th September 2019, 08:38 AM   #167
superlian is offline superlian  Norway
Is it possible to make a horn/waveguide like a splitted donut to get a cutoff around 5000 Hz on a 1 inch driver?
Or does it need a kind of rollback?
Old 9th September 2019, 06:56 AM   #168
mabat's Avatar
Could you make a sketch? I'm not sure I follow, I see "rollback" as inherent to a "splitted donut".
Old 9th September 2019, 07:36 AM   #169
I was thinking either a splitted donut or a ordinary horn (with rollback) but the latter is much more complicated to make
So the Q is. Will a splitted «donut» with a 1 inch opening glued to the 1 inch compression driver work as a horn/waveguide?
Old 9th September 2019, 08:25 AM   #170
mabat's Avatar
It will. Something like this, i.e. unbaffled?
Included are the project files for IB simluation (without a rollback), as well as the free-air shape in STL+MSH. Simulation for the free-air scenario (i.e. with the rollback) is not yet available, sorry.
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Copyright ©1999-2019 diyAudio
