Old 25th April 2020, 06:25 AM   #1531
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Here's the new waveguides from Samsung that have been patented, thanks to Ro808 for the link (US20200077180A1 - Waveguide for smooth off-axis frequency response
- Google Patents
Here's a waveguide similar to the Samsung waveguide, with eight slits
Here's a waveguide similar to the JBL "image control waveguides" with four slits
What I notice with this, is that the eight slit waveguide is about 2dB more efficient from 1-2khz, but the four slit waveguide is more efficient from 2-4khz.
Personally I prefer the four slit design. JBL seems to feel the same way; they've patented a waveguide with eight slits, but haven't sold any, AFAIK.
Old 25th April 2020, 07:02 AM   #1532
mabat is offline mabat  Czech Republic
mabat's Avatar
I have a new one
- Pick your favourite shape.
www.at-horns.eu
Old 25th April 2020, 07:33 AM   #1533
mabat's Avatar
Ath 4.5.0 has been released
First - the script files ARE NOT BACKWARD COMPATIBLE.
I'm sorry for this but I had to do it, otherwise the config items wouldn't make much sense anymore since a lot has been changed and rewritten. Please go through the manual, it's really not difficult to modify the old files for the new version if necessary. There are some different concepts of the geometry specification however. Don't hesitate to ask me.
ATH - Advanced Transition Horns
www.at-horns.eu
Old 25th April 2020, 08:01 AM   #1534
Dave Zan is offline Dave Zan  Australia
Originally Posted by Ro808 View Post
As in: a blacksmith is a smith who works with iron and may know s..t about horses?
A blacksmith works with iron to makes horseshoes but is too busy to make shoes for his own horse.
The modern idiom is that the car mechanic's car is never fixed.
Best wishes
David
Old 25th April 2020, 10:12 AM   #1535
mabat's Avatar
Originally Posted by mabat View Post
There has been some more results of even smaller waveguides during the recent months, based on my tools - ...
This was the smaller one, only 23 cm (~9") wide.
Measured with B&C DE502 (courtesy of Petr Mervart). These are great results for such a small horn, IMHO.
www.at-horns.eu
Old 25th April 2020, 11:32 AM   #1536
mabat's Avatar
Originally Posted by Patrick Bateman View Post
...Here's a waveguide similar to the Samsung waveguide, with eight slits ...
I see you have really mastered the piece
BTW, in 4.5.0 you can morph it to a circluar mouth outline as well.
www.at-horns.eu
Old 25th April 2020, 03:17 PM   #1537
gedlee is offline gedlee  United States
gedlee's Avatar
Would you consider this as a smooth enough transition? This is a waveguide of about the size of your Abbeys (12" woofer). The axial problems are also vitually gone (the graph is for 0 - 120 deg / 10). I would put this as my piece of evidence for all the points just mentioned. As for the curve C, I don't know if it is any special but a segment of an Euler spiral (or the curve corresponding to my waveguide formula) works very well as the remedy for most of the problems as you can see.
That device doesn't look axisymmetric, which is what I was talking about. Yes, it works very well, but that was not the point. I would like to see he actual DI curve as it can be very hard to tell from just polar plots.
Again, this is what hapens if you change the mouth round-over from abrupt to gradual for one particular axisymmetric OS waveguide - I don't know whether the hole is eliminated, went away or diminished to neglibility, but for the best transition it is just not there anymore.
There was never any question that a smoother mouth flare results in improved axial response, the question was if there is a better C than just a large radius. I don't see this as proving the point either way.
I'm not saying that one cannot do what you suggest, just that you make some generalized statements that I just don't see as true - in general. Your examples show specific cases that support your points, but they cannot be taken as generalizations of what happens in all cases.
Earl Geddes Gedlee Website
Old 25th April 2020, 04:09 PM   #1538
mabat's Avatar
Without any ambition to sound generic I think the data presented so far speak for themselves. And I believe that for such a smooth polars it should not be that hard to at least estimate the smoothness of the DI, it's really not that cryptic. There is really no issue with lowering the crossover point with a good horn (axisymmetric or not), that much is obvious I think.
I was actually quite specific when I said that based on my experience and all the results acquired so far, the waveguides in Gedlee loudspeakers could be improved by employng a better mouth flare with a more gradual change of curvature.
This all seems so obvious to me that I find it almost embarassing to discuss it further. It is perfectly fine if don't agree with me on this, that's really not my business.
www.at-horns.eu
Old 25th April 2020, 04:28 PM   #1539
gedlee's Avatar
I'm sorry if I embarrassed you, that was not my intent. But the statement "the waveguides in Gedlee loudspeakers could be improved by employing a better mouth flare with a more gradual change of curvature." is not proven by the data. If the waveguide is allowed to get larger then yes, this would be true, but given the physical constraints that I stated, it is not clear that it is true.
Old 25th April 2020, 04:32 PM   #1540
mabat's Avatar
When I designed those huge speakers (12" + 1.4" crossed at 650 Hz), I estimated the power response from the data - from this the DI is the difference between a (chosen) polar and the thick line. This was for the frontal hemisphere only.
www.at-horns.eu
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
