Thread Tools
Old 27th August 2019, 06:22 AM   #141
bmc0 is offline bmc0  United States
Hi Marcel,
I noticed that your program does not appear to match curvature between the OS section and the termination. The error is pretty small in most cases, but becomes obvious if Depth.ConicSectionPart is set to a low value (<0.3 or so).
Old 27th August 2019, 07:44 AM   #142
mabat is offline mabat  Czech Republic
mabat's Avatar
Yes, I realized this just after I released the tool... It's still tangent but curvatures at the joint may be (and will be) different. It's because I forgot to take the OS curvature into account - I just assumed it low enough, which is not allways true - especially near the throat, as you say. I will correct this. The solution is simple - to find the corresponding curvature on the clothoid and make the join at that point (now it's allways the origin of the spiral).
Thanks. At least someone is looking closely
https://at-horns.eu
Old 27th August 2019, 08:17 AM   #143
Glad to help. I noticed the issue after adding clothoid termination to my own waveguide generator script since I had made the same assumption that you did. I use a simple iterative algorithm to match the curvature, but I wouldn't be surprised if there's a better way (my math skills are a bit lacking compared to some others here ).
Old 27th August 2019, 08:20 AM   #144
mabat's Avatar
BTW, if an OS waveguide is terminated by just a circular arc (a simple radius), there will be a big step change in curvature ("2nd derivative") at this joint. It can be made much smoother with the spiral but as you can see, care must still be taken...
https://at-horns.eu
Old 27th August 2019, 12:57 PM   #145
mabat's Avatar
Ha ha, it won't be so easy after all - what must match is a curvature, tangency and a size at the same time. I guess some iterative algorithm will be necessary...
https://at-horns.eu
Old 27th August 2019, 08:52 PM   #146
mabat's Avatar
What we are talking about here - at the joint (the vertical line) curvatures don't really match. While the spiral begins with zero curvature the OS curvature is not yet near zero. It's quite difficult to notice but it's there.
https://at-horns.eu
Old 27th August 2019, 09:40 PM   #147
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Here's a 3D printed waveguide built using your software: Metlako: A Small, Affordable Two-Way Unity Waveguide
This is the 2nd I've done. I need to dig up pictures and measurements of the first.
Old 28th August 2019, 05:54 AM   #148
mabat's Avatar
Cool! Aren't you afraid of the sharp edges on the bigger one? I would guess it could wreak havoc on the frequency response (OK, the slits will do it anyway ).
https://at-horns.eu
Old 28th August 2019, 09:34 AM   #149
jzagaja is offline jzagaja  Poland
Great feature would be split model at printer table size then able to generate different throat size section and angle for particular driver.
email me jzagaja at gmail
Old 29th August 2019, 12:39 PM   #150
danibosn is offline danibosn  Croatia
does the ath4 generate STL file which can be opened by STL viewers.
If not what is "Out.Write_STL = yes"
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
