Thread Tools
Old 18th April 2020, 03:57 PM   #1301
mabat is online now mabat  Czech Republic
mabat's Avatar
For a slightly higher DI -
It's actually better on diagonal (SPL_D chart). This is 14" wide, 1.4" throat. The cyan line is for 45° off axis (7.5° step).
Dmitrij_S - good points, I suppose.
https://at-horns.eu
Old 18th April 2020, 04:33 PM   #1302
mabat's Avatar
Originally Posted by gedlee View Post
A flatter waveguide is always going to be smoother, but with less DI control. As the DI gets raised there will be more problems. ...
It is actually about 90° coverage nominally (the first one).
Will try to test a bigger one with 1" throat.
https://at-horns.eu
Old 18th April 2020, 05:15 PM   #1303
Ro808 is offline Ro808  Netherlands
Originally Posted by mabat View Post
This is also funny: Today, solely by mistake, I tried something I didn't want (what could be considered as an error), but hey, the result is one of the best I have seen -
Now I know how to improve things!
There you go
Old 18th April 2020, 05:57 PM   #1304
Originally Posted by Dmitrij_S View Post
I suppose, revolutionary improvement would mean
* Flat acoustic loading from 200-300Hz and up to the last audio octave (e.g. like Heavise or step Sigmoid function).
* Constant directivity in the same frequency range. (I suppose beamwidth of -+(20-30)° in all directions would be ok, at least for home audio).
*Horn-related acoustic nonlinearities would be comparable to that of the direct radiator.
*Perhaps, some kind of numerical criterion should specify a minimum value of HOMs amount.
"Revolutionary design" should improve all the point above at the same time. But as we know, "the horn reality" is completely different. Numerical optimisation helps to find a certain balance of contradictory horn parameters .
You mention 4, of which I came up with 3 myself.
Now some of Einstein's quotes would be appropriate, but redundant.
Old 18th April 2020, 06:06 PM   #1305
mabat's Avatar
So, this is 16.1" x 15.5" horn, 1" throat. There are obviously some wiggles from the analysis as this was still only a coarse setting. Otherwise pretty good, isn't it.
Again, cyan line is for 45° off-axis.
https://at-horns.eu
Old 18th April 2020, 06:09 PM   #1306
mabat's Avatar
OK, this is the magic (or half of it). I guess it would be even patentable
https://at-horns.eu
Old 18th April 2020, 06:26 PM   #1307
mabat's Avatar
One more.
https://at-horns.eu
Old 18th April 2020, 06:40 PM   #1308
So the rectum appears to work
Old 18th April 2020, 06:44 PM   #1309
mabat's Avatar
When done right
https://at-horns.eu
Old 18th April 2020, 06:50 PM   #1310
mabat's Avatar
The same for a circular one (16.2") - there is a very slight narrowing just below and around 2 kHz compared to the rectangular one.
https://at-horns.eu
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
