Thread Tools
Old 17th April 2020, 08:37 PM   #1291
Ro808 is offline Ro808  Netherlands
Originally Posted by mabat View Post
BTW, that shape is simply a result of the way they allowed the profile curves to change, which was very basic and still quite limited rule, IMHO (just bezier cubics, IIRC). So it is optimized in a sense that it may perform "best" within the limitations given. Which is of course true for any such optimization. Anyway, good luck with that!
Agreed. In the last 10 years we have seen horns with knuckles, mumbs, ridges and so on. Neither of these features has resulted in an evolutionary performance improvement.
Old 17th April 2020, 08:39 PM   #1292
mabat is online now mabat  Czech Republic
mabat's Avatar
Originally Posted by Ro808 View Post
... Neither of these features has resulted in an evolutionary performance improvement.
And that would be...?
https://at-horns.eu
Old 17th April 2020, 10:30 PM   #1293
You're smart enough to come up with some desirable features, but to give an obvious example:
- Elimination of interferences.
Old 18th April 2020, 05:34 AM   #1294
mabat's Avatar
No I really tried to imagine an evolutionary performance improvement in horns but really can't think of any. Maybe that's also the reason I won't ever come up with any
Interferences? Well, I "could" imagine a driver+horn combo reaching a pure spherical wavefront - that would be an improvement!
https://at-horns.eu
Old 18th April 2020, 03:00 PM   #1295
gedlee is offline gedlee  United States
gedlee's Avatar
Someone is confused, maybe me!
Ro808 stated:
Which, to me, means that these features have not resulted in any improvements.
but Mabat says:
Which says, to me, the exact same thing.
Do you guys agree or disagree? It's not clear.
I too was unclear what was meant by "interference".
And yes a "pure spherical wavefront" would be great, but you should also state that this should occur across the bandwidth. A spherical wavefront at one frequency is not so difficult, but at all frequencies, it is likely impossible.
Earl Geddes Gedlee Website
Old 18th April 2020, 03:05 PM   #1296
mabat's Avatar
This is funny. We agree about the improvements (there have been none). But Ro808 says he's sure I'm able to come up with some ideas what the possible improvements in horns could be. And I say I'm really not...
https://at-horns.eu
Old 18th April 2020, 03:08 PM   #1297
mabat's Avatar
This is also funny: Today, solely by mistake, I tried something I didn't want (what could be considered as an error), but hey, the result is one of the best I have seen -
https://at-horns.eu
Old 18th April 2020, 03:19 PM   #1298
mabat's Avatar
Now I know how to improve things!
https://at-horns.eu
Old 18th April 2020, 03:21 PM   #1299
gedlee's Avatar
A flatter waveguide is always going to be smoother, but with less DI control. As the DI gets raised there will be more problems. My goal has always been as high a DI as I can get in a reasonable configuration and this always leads to tradeoffs.
Old 18th April 2020, 03:51 PM   #1300
Dmitrij_S is offline Dmitrij_S  Europe
Dmitrij_S's Avatar
I suppose, revolutionary improvement would mean
* Flat acoustic loading from 200-300Hz and up to the last audio octave (e.g. like Heavise or step Sigmoid function).
* Constant directivity in the same frequency range. (I suppose beamwidth of -+(20-30)° in all directions would be ok, at least for home audio).
*Horn-related acoustic nonlinearities would be comparable to that of the direct radiator.
*Perhaps, some kind of numerical criterion should specify a minimum value of HOMs amount.
"Revolutionary design" should improve all the point above at the same time. But as we know, "the horn reality" is completely different. Numerical optimisation helps to find a certain balance of contradictory horn parameters .
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
