Thread Tools
Old 12th July 2019, 05:45 AM   #101
mabat is offline mabat  Czech Republic
mabat's Avatar
Originally Posted by Hylle View Post
When you talk exit angle on a compressiondriver, how is that defined?
Usually there is some length of a conical section at the very end of a driver exit, so this cone opening angle is meant by that - the horn should then just match smoothly. There are exceptions.
https://at-horns.eu
Old 12th July 2019, 05:56 AM   #102
mabat's Avatar
Originally Posted by Gaga View Post
... I'd appreciate to get a *.step-file as well, which would ease up the transfer to a CAD program to finally print the horn. Any possibility?
Hi Christoph,
that's not at all easy. To get a STEP or IGES file I would have to use some surface splines (NURBS) to get the same results as I have now and I'm not sure I'm willing to do that. I agree that STL is probably not really the best option but it's all I have for now - it's just very easy to do. I could make the STL as a volume instead of just a sheet - that may ease the processing, I don't know. But as I understand, there are ways to do that in CADs.
I will add an option of a "point cloud" output. That may also help some.
https://at-horns.eu
Old 12th July 2019, 06:02 AM   #103
mabat's Avatar
Originally Posted by carlthess40 View Post
Can this program be use to make full range wood horns? Or mid/high wood horns?
You would have to explain what do you mean by that. The program uses some basic set of parameters to get a horn. It depends on your needs if this is sufficient or not. Basically you can combine hyperbola and a clothoid in various ways along the contour, in any dimensions you like.
https://at-horns.eu
Old 12th July 2019, 10:42 AM   #104
mabat's Avatar
I thought about the dome tweeters. The biggest problem I see might be that the real dome (especially a soft one) will not move coherently as a one body at the higher frequencies where the simulation would be the most interesting. I will probably implement it, as it is not difficult, but I would be hesistant to make much of it. Maybe for hard domes it will give more reliable results. But hey, it's similar to compression drivers flat wavefront assumption.
https://at-horns.eu
Old 12th July 2019, 02:28 PM   #105
danibosn is offline danibosn  Croatia
Hi guys
I know that you are already couple of steps forward but need some help with ath4 application.
I followed instructions, extract ath4, copy in same directory gmsh-4.3.dll, made cmd shortcut and copy file path in "start in". When I double click cmd shortcut nothing happen, actually new cmd window blink for a second and disappear. I rename ath4 to ath4.exe and tried again, same thing.
After that I've tried to go regular procedure: open cmd, type cd (file path), enter, type start and application name (both ath4 and ath4.exe) and same thing happens.
After first fail I deleted all files and download and repeat everything again on two computers with same results.
So please is there any known solution ...
Old 12th July 2019, 02:45 PM   #106
mabat's Avatar
Don't type "start ath4", just "ath4".
There is a chapter "3. Working example" in the user guide. Please go step by step as shown. You will also need to change the output directory in the script file(s): Out.DestDir = "..."
http://www.at-horns.eu/release/Ath4_UserGuide.pdf
https://at-horns.eu
Old 12th July 2019, 03:25 PM   #107
1hiep0 is offline 1hiep0  United States
I see that you could view .stl but could it be used to modify? Would be nice.
Thanks,
Old 15th July 2019, 04:30 PM   #108
Thank' Marcel
of course it was about me, after follow manual and your advice's everything working fine
Old 16th July 2019, 06:32 AM   #109
mabat's Avatar
BTW, an interesting driver for home use seems to be the new Celestion CDV1-1757.
CDV1-1757 - Vocal Range Compression Driver
https://at-horns.eu
Old 16th July 2019, 06:48 AM   #110
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Hi Marcel,
I've found that 3/4" dome tweeters work really nicely on horns and waveguides. The SB Acoustics SB19 works on virtually every waveguide I've come across.
I agree that a lot of dome tweeters are useless on horns and waveguides, but there are a handful that work nicely.
Thread Tools
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
