Old 14th February 2020, 04:20 PM   #1031
gedlee is offline gedlee  United States
gedlee's Avatar
When I saw this paper at AES I swear they were using a wire microphone which measures velocity not pressure. In theory a two plane idea should work, but I would be concerned with measurements unless the mic was extremely small.
Really there are many ways to solve this problem and which works best remains to be seen, but none have actually come to be widely used and as such there is no data on performance.
Earl Geddes Gedlee Website
Old 14th February 2020, 04:43 PM   #1032
mabat is offline mabat  Czech Republic
mabat's Avatar
They mention B&K 4138 (~3.2 mm) or Sennheiser KE-4 (~5 mm). So if a 5 mm electret capsule should suffice (?), I'm quite tempted to try at least, even if I should move the driver manually on some primitive frame - that would cost next to nothing. Your technique looks most interesting and I would prefer that, I'm only scared of the math involved - not something I could cope with in a case of any trouble. This is the complete opposite - can't be any simpler.
www.at-horns.eu
Old 14th February 2020, 05:08 PM   #1033
gedlee's Avatar
I could help with the math, let me find my notes. The biggest issue would be the matrix inversion as these can be problematic. One would likely need to use SVD, but algorithms for that are widely available these days. If you are comfortable with matrix inversion and SVD then I don't think that you would have a problem.
The Makarski technique uses a free field driver, correct? That would bother me as this is not the boundary condition that the driver would see in practice.
Old 14th February 2020, 05:12 PM   #1034
mabat's Avatar
We already touched that, if that's what you mean: #394, #395
OK, why not to try (both). I already looked for some aluminum tubes around, I can get 25 and 35 mm of inner diameter, up to 6 m long. I'd start a new thread when I have it ready (one mic only for the start).
Yeah, that puzzles me as well. But neither the tube is...(?)
www.at-horns.eu
Old 14th February 2020, 08:34 PM   #1035
gedlee's Avatar
Yea, that's the basic math. There is an excellent AES paper by my friend at B&C (Magalotti) on making PWT. You should look it up.
Old 14th February 2020, 08:53 PM   #1036
mabat's Avatar
I found this one, which also references the Magalotti paper. For $33 I could buy most if not all of the material to actually build the PWT, I guess
AES Information Document for Acoustics - Plane-Wave Tubes - Design and Practice
www.at-horns.eu
Old 14th February 2020, 11:53 PM   #1037
gedlee's Avatar
Well that paper certainly works for background! Just need to space the mic ports along the tube, probably in some random, certainly not equal, spacing. How many is up to you and your computational capacity.
Old 15th February 2020, 12:00 AM   #1038
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I'll buy you an AES membership if you like, I've certainly got $125 worth of use from your software
Old 15th February 2020, 04:09 AM   #1039
Dave Zan is offline Dave Zan  Australia
The latest MEMS microphones have tiny ports, pretty decent specifications and cost only a few dollars each so well worth consideration.
Best wishes
David
Old 15th February 2020, 06:45 AM   #1040
mabat's Avatar
If I make the tube long enough to obtain a sufficiently long reflection-free time, I can make gated IR measurements and don't have to bother with damping at all, correct? How long is enough - 5 ms? That would be about 1.5 m of tube, which is perfectly fine. Is there any reason why not to do it this way?
www.at-horns.eu
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
