Old 13th February 2020, 01:02 PM   #1011
mabat is offline mabat  Czech Republic
mabat's Avatar
Now this is a 1" (25,4 mm) and 1,4" (35 mm) driver in 90 waveguide -
www.at-horns.eu
Old 13th February 2020, 02:58 PM   #1012
mabat's Avatar
I think the pattern is obvious (and it has been said many times) - as the coverage angle is increased or the throat made larger, the lower in frequency come all the HOMs into play - the device deviates from constant directivity of a pure spherical wave. The flat baffle being a special case of the maximum coverage angle, i.e. the worst case for a given throat size.
www.at-horns.eu
Old 13th February 2020, 03:25 PM   #1013
gedlee is offline gedlee  United States
gedlee's Avatar
Mabat
Thanks for those plots. They prove what I have said from the beginning: that a waveguide does not have the polar limitations of the source. This was predicted by the theory, shown by my measurements and now again shown by simulations. I hope this puts this incorrect belief to bed, Finally!
The waveguide does narrow as the angle is made wider, but this is not driver dependent at all. In reality driver wavefront coherence degrades at the upper frequencies and that causes reality to differ from the theory, but this is due to the inability of specific drivers to maintain a flat wavefront. It is not inherent in the design itself.
Improved phase plugs may help this situation, but little to nothing is known about the flatness of driver exit waveforms. About a decade ago I showed (B&C) how this situation could be measured in a PWT, but it was never followed through. To me, that would be the next piece of the puzzle that will need to be analyzed in order to progress the directivity control to ever higher frequencies - if that indeed is actually worth doing.
I have my doubts.
Earl Geddes Gedlee Website
Old 13th February 2020, 04:09 PM   #1014
mabat's Avatar
I think what may be easily misleading here is the notion of a directivity of a source by itself, without considering any boundary conditions, or thinking of a directivity pattern in an infinite baffle as something inherent to the source. Change the boundary conditions and the whole situation is different.
For me the good news is the confirmation that 1,4" drivers can be used without a problem, provided they output a high quality wavefront. Many of the modern ones seem to be quite good.
www.at-horns.eu
Old 13th February 2020, 05:36 PM   #1015
impuls60 is online now impuls60  Norway
Does the Coanda effect matter in horns? Looking at the knuckles in the M2 I would think the Coanda effect would appear over those bends.
Old 13th February 2020, 05:52 PM   #1016
mabat's Avatar
You would need an air flow for that. That doesn't happen when playing music
www.at-horns.eu
Old 13th February 2020, 08:21 PM   #1017
gedlee's Avatar
This is precisely the same answer that I always gave, but people just didn't buy it.
Your math understanding of this is very good. I just wish that I had your tools back-in-the-day. The first solution of the OS waveguide took me more than a year. Now its a few minutes!
Old 13th February 2020, 08:34 PM   #1018
mabat's Avatar
Originally Posted by gedlee View Post
The first solution of the OS waveguide took me more than a year. ...
Oh you must have had a great time
www.at-horns.eu
Old 13th February 2020, 11:06 PM   #1019
Dave Zan is offline Dave Zan  Australia
Oh no, we are back at this...
there must be a continuum...
Any comments...
First comment is- thank you very much, this is exactly the data I have tried to find.
The continuum issue is one I raised with Earl but never came to any conclusion.
I will try to write a sensible comment after I think more about your posts.
They deserve a considered response, excellent work.
Best wishes
David
Old 14th February 2020, 03:02 AM   #1020
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I have my doubts.
I'd really love to play around with the JBL 2409H and the 2410H but they're not easy to buy. (Not for sale at retail.)
The 2409H is in the JBL 705P and it has a 16mm throat (21,250Hz)
The 2410H is two years newer, and it has a 25mm throat (13,600Hz)
The phase plug of the 2410H extends all the way into the horn.
This makes me wonder if the latter solution worked better than the former solution.
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
