Old 13th February 2020, 03:51 AM   #1001
norman bates is offline norman bates  United States
norman bates's Avatar
post 993.
the graph on the right (when 2 graphs shown), that is the non knuckles ?
Response looks really good to me (compared to so so much) on the non knuckles.
what are the graphs, left to right again ? vertical, horizontal, diagonal ?
Old 13th February 2020, 08:22 AM   #1002
mabat is offline mabat  Czech Republic
mabat's Avatar
Originally Posted by cowanaudio View Post
Try measuring a bare compression driver, they show significant pattern control above 10KHz. How can a waveguide without a diffraction slot make this wider? I'm assuming your "waveguide done properly" does not have a diffraction slot.
Oh no, we are back at this again
OK, I just quickly simulated the following two cases:
a) 175deg OS waveguide, i.e. almost a flat baffle, which is really the limiting case for an OS waveguide as coverage angle approaches 180deg;
b) 90deg OS wavaguide.
The pictures will follow...
www.at-horns.eu
Old 13th February 2020, 08:23 AM   #1003
mabat's Avatar
A "flat baffle" case (175deg coverage):
www.at-horns.eu
Old 13th February 2020, 08:24 AM   #1004
mabat's Avatar
90deg waveguide:
(Both cases for 1" throat.)
www.at-horns.eu
Old 13th February 2020, 08:26 AM   #1005
mabat's Avatar
Since the flat baffle is the limiting case for an OS waveguide as the coverage widens (up to 180deg), there must be a continuum.
Any comments or suggestions?
- Does anyone know how to thicken the plot lines in VACS?
www.at-horns.eu
Old 13th February 2020, 09:02 AM   #1006
mabat's Avatar
Originally Posted by fluid View Post
Seems the over 10K response is smoother without the big dip in the M2 clone, could you extend the sim to go to 20K to see it better?
I can but it makes a huge difference in BEM running times. I try to limit the mesh resolution as possible to speed things up. There's still a lot to look at and improve between 1k - 10k. IMO, there's too many unknowns above 10 kHz that it makes little sense to try to simulate it this way. I can try occasionally. This might be an interesting case.
www.at-horns.eu
Old 13th February 2020, 09:10 AM   #1007
mabat's Avatar
120deg OS waveguide -
www.at-horns.eu
Old 13th February 2020, 09:21 AM   #1008
mabat's Avatar
Originally Posted by norman bates View Post
post 993.
Yes.
Yes. The graphs are labeled "SPL_H / SPL_V / SPL_D" accordingly.
www.at-horns.eu
Old 13th February 2020, 09:57 AM   #1009
mabat's Avatar
...some may be waiting for 60 degrees (Mind the scale shift.)
www.at-horns.eu
Old 13th February 2020, 10:47 AM   #1010
mabat's Avatar
60, 35 mm driver exit. Up to about 15k it's virtually without a change compared to 1".
www.at-horns.eu
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
