Old 22nd June 2019, 11:48 PM   #91
mrk7 is offline mrk7  Australia
mrk7's Avatar
Originally Posted by Patrick Bateman View Post
Yes, this would be an awesome feature. One way you might implement it is to add a stanza to the cfg file for the following:
1) diameter of dome
2) diameter of surround
3) height of dome
You might want to set things up so that these parameters would override the "ThroatDiameter" parameter. In other words, if the user selected a 25mm dome with a 5mm surround, that would yield a throat of 35mm. So if the user selected a throat of 25mm or 50mm, that would cause issues with the model. (Because there's a mismatch.) So you might want to have the dome settings "override" the "ThroatDiameter" setting in the config file.
Great idea Patrick Bateman!
Old 23rd June 2019, 04:46 PM   #92
OscarS is offline OscarS  United States
3D printer
Check out my threads on how to make waveguides in 123D. The same ideas apply to an AMT. Basically you want a spline which gently connects the output of the radiator to the baffle. That's why these waveguides have these big roundovers.
I figured that would be the answer, I just wasn't sure if everyone and the kid down the block were buying their own 3D printers or if they were having them outsourced somewhere.
I modified a home-brewed Dayton H110 horn to an AMT and the results were fantastic for what I needed, but I'm torn as to how to make the aesthetics better. V1.0 was fiberglass/resin to match the throat to the AMT aperture. V1.2 (in the works) will be slicing/merging two H110 horns to get the throat dimension I need without resorting to fiberglass/resin. But of course a 3D printed horn would be even better!
Old 24th June 2019, 08:55 PM   #93
Ro808 is online now Ro808  Netherlands
Originally Posted by mabat View Post
Now I see I wrote 52 exit angle for 4554 - that is nonsense, it is 26 total. OK, I found 4550 has about 14.
Exit angle of the BMS 4554 is 26.7 (confirmed by BMS).
I have 2 pairs, Mk1 (metal brand plate) and Mk2 (plastic brand plate), exit angles are identical.
Old 11th July 2019, 08:48 AM   #94
Gaga is offline Gaga  Europe
Hi mabat,
Thanks a lot for presenting your software here!
I just started to play around with it a bit and have a few questions/comments:
- There is a new gmsh-version 4.4 out. When I installed the gmsh-4.4.dll file, it didn't work. I had to install the 4.3-file. Is this ok - or would you update your prog to gmsh 4.4?
- I did run the 'small' example first. Had the same issue as previously described here, i.e. had to modify the output-folder path. Everything fine then.
- When running ath4 I got the ABEC project result and mesh-file. I'd appreciate to get a *.step-file as well, which would ease up the transfer to a CAD program to finally print the horn. Any possibility?
I could make an option of a dome tweeter instead of a plane wave (which is what it is now) for the throat. At least I believe it would be possible. Only it is not so obvious how to do it. Should I include the surround? How to define the shape? Or does that make any sense at all?
This would be great. I fully agree with Patricks comments here.
Thanks again for this great piece of software,
Christoph
Old 11th July 2019, 12:22 PM   #95
Hylle is offline Hylle  Denmark
When you talk exit angle on a compressiondriver, how is that defined?
Old 11th July 2019, 03:40 PM   #96
danibosn is offline danibosn  Croatia
Christoph
Hi
First I would like to thank Marcel for giving to community such piece off tool
Second is that I have same problem as Gaga but could not find download link for gmsh 4.3. So if somebody has a link, please, post it
regards
Old 11th July 2019, 03:48 PM   #97
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
1) measure the diameter at the exit of the phase plug
2) measure the diameter at the throat
3) use the pythagorean theorem to calculate the exit angle
Old 11th July 2019, 03:55 PM   #98
Yes, it's not obvious. The link is given at the main page:
All versions: binaries and sources
The direct link for Windows is here under 'http://gmsh.info/bin/Windows/'.
Just download the 4.3. version.
Old 11th July 2019, 04:13 PM   #99
carlthess40 is offline carlthess40  United States
Can this program be use to make full range wood horns? Or mid/high wood horns?
Old 11th July 2019, 05:59 PM   #100
Thank's Gaga
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 05:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 08:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 11:32 AM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 08:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 08:01 AM
Copyright ©1999-2019 diyAudio
