Baffle Shape for Smooth Frequency Response
Old 29th May 2019, 01:28 AM   #1
solacedagony is offline solacedagony  United States
Default Baffle Shape for Smooth Frequency Response
I'm building a 3 way speaker with Satori drivers and for fun, I've been simulating different baffle shapes in VituixCad with the goal of smooth frequency response. I ended up coming up with this baffle shape which seems to give a smoothish response.
My thought is that if the baffle dimension is constantly changing radially with the correct change function, you should be able to get a smooth response. I just made the change function linear because I wasn't sure what the correct one is although I'd guess exponential or logarithmic would be the right one. I made the longest dimension the crossover frequency.
I was also surprised that even on a rectangular baffle if the speaker placement is right, you can pretty well smooth the response.
Any thoughts on this? I haven't listened or measured it yet.
Are there any other shapes I should look into or experiment with?
Old 29th May 2019, 02:05 AM   #2
Bill Coltrane is offline Bill Coltrane  Netherlands
Olsen in the 1950's came up with this.
Subjective measurements with the proper protocol is the only thing that matters.
Old 29th May 2019, 02:11 AM   #3
Thanks for the graphs Bill!
I was also going to build a sphere for experimentation because I've never heard a speaker with a spherical enclosure.
I'm guessing the charts assume a point source. What would a driver with a finite cone area do to the response?
Old 29th May 2019, 03:05 AM   #4
LineSource is offline LineSource  United States
LineSource's Avatar
2" - 3" radius quarter round machining on Left / Top / Right baffle edges is used on:
Kii-3
Vapor cabinets
Magico cabinets
B&W 802
Side woofer(s) are used to allow modest width front baffles when large radius / bevel cuts are used to reduce diffraction.
The truncated pyramid bevel cuts as used by Avalon have proven low distortion advantages and artistic value.
Old 29th May 2019, 04:25 AM   #5
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Wait! You started with the baffle -so projection of the waves forward only; now considering the enclosure, you put into the "equation" the front wave, the backwave, the front wave travelling in space and returning to the enclosure-and then back again.
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 29th May 2019, 05:24 AM   #6
celef is offline celef
How about a very wide baffle?
Old 29th May 2019, 06:17 AM   #7
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Poor mans Stradivarius?
Poor Man'
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 29th May 2019, 06:42 AM   #8
Pida is offline Pida  Czech Republic
Larger radius or elliptical rounding are probably the best, and moreover it looks good. If you add waveguide it will be even better. For example, 170mm WG and edge rounding 30mm, 220mm wide baffle.
See some of my projects:
PKAudio: DIY loudspeaker projects
Old 29th May 2019, 11:21 PM   #9
InOtIn is offline InOtIn
Petr,
That's some really impressive builds you've got there, both physically and electrically. Will definitely bookmark your website and follow your progress on the ones still in development. Just wish the whole site would have English translation.
Since you've played with all three, what's your subjective perception of the NE123, MR16P and the 12MU vis--vis each other? Also of the WO24P since you chose to sell it.
Old 30th May 2019, 12:15 AM   #10
If I understand what you're saying correctly, I didn't factor in frequency response of the driver itself, the effect of the enclosure on the low end rolloff, the off axis response and reflections? That is true, I'm still learning a lot and taking it piece by piece. I am a relative noob at all this.
Baffle Shape for Smooth Frequency ResponseHide this!Advertise here!
Open Baffle 8 inch fullrange driver , bottom frequency response. santitrucco Full Range 12 7th November 2018 08:12 AM
Baffle Shapes and Frequency Response cogitech Construction Tips 19 28th September 2011 02:21 AM
Getting good Efficiency and smooth response, to 3-4-5-way, or not pjpoes Multi-Way 86 31st July 2008 10:56 PM
Need to smooth upper bass of sub response... eRiCdWoNg Subwoofers 4 27th August 2003 03:01 AM
Copyright ©1999-2019 diyAudio
