Redesigning my cabinets. Thoughts?
Old 15th May 2019, 09:11 PM   #21
3wayaddict is online now 3wayaddict  Netherlands
3wayaddict's Avatar
So I got a design with both woofers in the top but still with separate chambers in "L" against each other. Though this means the chamber are quite long from the driver to the end of the chamber. Will this cause standing waves to occur again or won't it be that bad?
When you do it, do it right. Go all out.
Old 15th May 2019, 09:50 PM   #22
ICG is offline ICG  Germany
ICG's Avatar
That will still give you standing waves, the frequencies shift though. The lower red 'L' is wrong though, either the holes on the bottom have to be closed or (that's what it looks much more likely) you've drawn the 'L' too short and it one brace more to the volume. But then the most distances are the same distance or at least close to each other, which then gives you standing waves on the same frequency in 2 directions. I don't know the measurements and therefore where the standing waves frequencies will be.
You could also build it with tube absorbers. That would solve it too.
Why don't you use an angled board? You don't have to 3d mill/route that one, to be close to it and file off the edge (in front and back) a bit is enough, you can glue that with polyurethane glue, that will close the gap airtight and it's not visible anyway.
I had a Déjà Moo - I've seen that BS before!
Old 15th May 2019, 10:12 PM   #23
3wayaddict's Avatar
Yeah I drew the bottom L wrong.
What do you mean with the angled board? Where and what for?
Old 15th May 2019, 10:49 PM   #24
ICG's Avatar
Standing waves occour at parallel surfaces. Avoiding it being parallel..
File Type: png Schermafbeelding 2019-05-15 om 22.14.27-2.png (217.9 KB, 70 views)
Old 15th May 2019, 10:56 PM   #25
3wayaddict's Avatar
Yeah that would be nice. It's gonna be hard to do because of the curved walls though but I'll try my best
Old 16th May 2019, 12:25 AM   #26
ICG's Avatar
Like I said, it doesn't have to be perfect, if you use PU glue, it will fill the gaps, the glue expands, a few mm are no problem.
Old 16th May 2019, 04:49 AM   #27
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
… curved sides for extra stiffness ...
The reason a curved wall is stiffer is because you are forcing a flat piece of material into a curve. You do not get this with trans-lam construction — it is good for getting unusual shapes, but i think everything else about this approach sucks.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th May 2019, 04:54 AM   #28
frugal-phile(tm)
planet10's Avatar
If you are doing translam this way:
Then these ribs are not braces:
Braces would need to run vertically so that the brace contacts each translam piece.
dave
Old 16th May 2019, 05:43 AM   #29
3wayaddict's Avatar
That's what I did with the latest version with the vertical brace.
Old 16th May 2019, 07:00 AM   #30
frugal-phile(tm)
planet10's Avatar
You should lose almost all the horizontal ones, because it is translam in the same orientation, they do very little. I’d brace the drivers to the back of the cabinet (spine-like) and then a couple off to the sides.
Now if you were to skin that frame with a flat-panel you could get the stiffness from forcing a curve, and the bracing would be useful.
These use a similar skeleton, then 3 layers of 6mm rubberply and then 9mm. Vacuum bag and a substantial form to make the curves.
We used the same sides for these (before veneer):
You are showing imaging a bit with tighter radii. Quite doable.
If you want to be over the top this is the way to do it. But a lot more work.
Out there somewhere is a video clip of the large dedicated press used to turn many thin players of wood into a 32mm thick curved plywood shell for the B&W Nautilus 801.
dave
Redesigning my cabinets. Thoughts?Hide this!Advertise here!
Redesigning filter, need help! buestad Multi-Way 25 4th April 2018 01:31 PM
Super Pensil Cabinets with TB W8-1808 Drivers - Thoughts? tlarwa Planet 10 hifi 11 3rd December 2014 08:09 PM
Help redesigning active 3-way baffle DWP Multi-Way 4 10th June 2014 01:23 AM
Looking for thoughts and advice on some old cabinets djmeverett Multi-Way 8 27th June 2012 04:52 AM
Redesigning the Thor planet10 Multi-Way 14 19th August 2003 07:22 AM
Copyright ©1999-2019 diyAudio
