Redesigning my cabinets. Thoughts?
Old 22nd May 2019, 01:08 PM   #141
3wayaddict is offline 3wayaddict  Netherlands
3wayaddict's Avatar
Philosophy is different from physics.
When you do it, do it right. Go all out.
Old 22nd May 2019, 01:09 PM   #142
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
You didn't read it all?
Old 22nd May 2019, 01:10 PM   #143
3wayaddict's Avatar
It's kind of like the argument that if you've eaten today world hunger is fake news.
Old 22nd May 2019, 06:36 PM   #144
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by 3wayaddict View Post
Maybe think and make sure it isn't nonsense before you say something. First of all these are plate ams designed to be mounted in the speaker cabinet, that's kind of the entire point of a plate amplifier. Though obviously it isn't designed to be part of the outer wall of the cabinet, it has vents in it, and obviously isn't any rigid. Which is why I put it in its own chamber. I think this was pretty obvious already because I think I probably mentioned the "amplifier chamhttps://www.youtube.com/ber" before in this thread and I think it's pretty self-explanatory it should be in it's own chamber anyway. It has literally been in the design from the start.
Come on, do you think I'm stupid? I graduated literally yesterday.
You certainly are not stupid. Some seemingly logical combinations can easily mislead you. However, you are not wrong in this case at all. But stupidity or intelligence should not be confused with little/less experience in some sectors. And you can't think of all and everything since some things actually need said experience.
I would like to suggest a change of the amp mounting. Most plate amps got elements sticking out of the front plate. That means, if your amp does and you move the speakers, the first thing on the back hitting anything are the stick-out plugs, potentiometer(s) etc. and that will damage your plate amp. That can easily be avoided. So it's a very good idea to not mount it flush with the enclosure but to recess it about that far the farthest extended part of the plate amp is protected. You could also achieve that by mounting a strip of hard wood at the edges of the amp opening or similar but it will ofcourse not look that good and is easily spotted.
I had a Déjà Moo - I've seen that BS before!
Old 22nd May 2019, 10:47 PM   #145
3wayaddict's Avatar
I don't see a problem in that. Just don't shove them against the wall.
Old 22nd May 2019, 11:24 PM   #146
InOtIn is offline InOtIn
Originally Posted by scottjoplin View Post
"If a speaker moves the air inside a cabinet and no one is inside to hear it, does it make a sound?"
According to Heiselberg’s Uncertainty Principle, the answer is yes and no, or both, until someone is actually inside the cabinet and observes/listens.
Old 22nd May 2019, 11:32 PM   #147
You mean like [a certain President] - if it’s snowed today, global warming must be fake news
Old 23rd May 2019, 03:20 AM   #148
ICG's Avatar
You probably don't do that. I mean, intentionally. But you or a friendly helper can easily do that accidentally while a move etc - it's not a problem now but it can be an expensive one in a few years. And if you don't build the amp yourself, it's very possible or even likely you can't get a replacement with the same dimensions. That means, (besides saving money for an amp replacement), you'll also save the money for a new enclosure (or modifying it and paint/varnish it again) or having a separate amp box and spider-web-like cables laying around. Believe me, I've seen my share in smashed in plate amp boards. Anyway, it's your speaker, after all. But I always thought you don't have to make ALL mistakes by yourself.
Old 23rd May 2019, 03:46 AM   #149
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I agree wit ICG, when we build a speaker, we do not like to have anything sticking out that could be accidently broken off because they stick out.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd May 2019, 04:37 AM   #150
ICG's Avatar
It's worse. If it's just broken off, it can usually be replaced. Annoying but manageable. The real problem is when the pushed in plugs etc. smash the amplifier board itself. Even with little visible damage it often leads to a hair thick crack in the boards conductive layer, very hard to find, often only losing contact when a temperature change occurs, causing the amp to stop working or worse, the 'thump noise' or DC on output when happening, killing the driver.
Redesigning my cabinets. Thoughts?Hide this!Advertise here!
Redesigning filter, need help! buestad Multi-Way 25 4th April 2018 01:31 PM
Super Pensil Cabinets with TB W8-1808 Drivers - Thoughts? tlarwa Planet 10 hifi 11 3rd December 2014 08:09 PM
Help redesigning active 3-way baffle DWP Multi-Way 4 10th June 2014 01:23 AM
Looking for thoughts and advice on some old cabinets djmeverett Multi-Way 8 27th June 2012 04:52 AM
Redesigning the Thor planet10 Multi-Way 14 19th August 2003 07:22 AM
Copyright ©1999-2019 diyAudio
