Horn Lens for BMS 4594HE
Old Yesterday, 01:03 PM   #51
Audiodidakt is offline Audiodidakt  Norway
I would be interested in that, jzagaja!
Old Yesterday, 01:17 PM   #52
pk is offline pk  Denmark
Hi Jzagaja,
I am interested as well! How about an up-scaled version of the EOS 250 - maybe an EOS 180 or EOS 200?
Best regards
Peter
Originally Posted by jzagaja View Post
I'm trying to organise group buy for large waveguide (translucent) with 3D printed throat for various drivers or/and unity type.
Then how to match large waveguide with slim bass baffle?
Old Yesterday, 03:25 PM   #53
jzagaja is offline jzagaja  Poland
I already made such - AiA Cinema model Black Swan (2" throat, 3deg, 60x40). Alternative is Marcel's work:
hifi.slovanet.sk :: Zobrazi? t?mu - Zvukovody STH - teorie a praxe
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old Yesterday, 04:27 PM   #54
superlian is offline superlian  Norway
Will it perform well without a tweeter with a 1,5 inch beryllium driver?
Old Yesterday, 04:53 PM   #55
I'm sure it will.
Old Yesterday, 05:10 PM   #56
As good as JBL 2384?
(With D2 driver)
Old Yesterday, 05:30 PM   #57
It's different.
File Type: jpeg 7DBA9A9C-EFD7-44B1-ACA8-532364E3B1AA.jpeg (71.4 KB, 51 views)
Old Yesterday, 06:18 PM   #58
Hi Jzagaja,
I was thinking even bigger than the EOS 250. The upcoming 1.4" B&C DCX464 has an Fs around 250 and may therefore be fine for home use down to 220-250 Hz on a sufficiently large horn/waveguide.
Getting below 300 Hz makes the integration with a woofer much easier!
Best regards
Peter
Old Yesterday, 07:07 PM   #59
I'm limited to 900x1900mm. DCX464 will be tested with above.
Old Yesterday, 07:56 PM   #60
Hi Jzagaja,
It sounds really interesting that you van make horns/waveguides even bigger than the EOS250. Please keep us posted about your impressions of the DCX464 on the EOS250 - thanks!
Best regards
Peter
Horn Lens for BMS 4594HEHide this!Advertise here!
Double 10 BMS 4594HE B&C 10NDL64 Cnyg PA Systems 5 14th January 2018 06:43 PM
FS - Altec 604-8G Horn Lens (original) vt4c Swap Meet 0 10th May 2017 02:20 AM
Dual 16 ohm BC 12ndl76 +BMS 4594HE 1.4" exit coax sine143 Multi-Way 9 31st March 2017 09:35 PM
JBL HL92 Horn / Lens Assemble TomHinton Swap Meet 0 5th January 2015 01:35 AM
DIY horn lens? ViolenceOnTheRadio Multi-Way 3 3rd October 2010 11:15 AM
Copyright ©1999-2019 diyAudio
