Horn Lens for BMS 4594HE
Old 9th May 2019, 04:05 AM   #11
rotgg is offline rotgg  United States
Originally Posted by ErnieM View Post
Make sure you set your limiters fairly conservatively. Don't want to read about fried drivers in a few months! While the AE drivers are second to none in audio performance, they aren't designed for the abuse that pro audio gear goes through.
Most people associate distortion with loudness. These drivers might fail before that threshold is reached for select individuals.
From what I have read about the AE drivers I thought they were extremely tuff. I read somewhere that someone was using them in pro audio gear for concerts and live events for like 8yrs with only one fail.
Old 9th May 2019, 04:50 AM   #12
AllenB is offline AllenB  Australia
You said low as possible, then you said not easy to blow. These two are a tradeoff. They contradict each other. Directivity may need to be a secondary concern.
The type of horn can be different for these two needs. If you want loud then consider a narrow throat expanding horn, and accept its limits. If you want low consider something more conical.
Old 9th May 2019, 04:51 AM   #13
jzagaja is offline jzagaja  Poland
Originally Posted by rotgg View Post
that looks great but what is it
300Hz waveguide, 1x0,5x0,5 meter, 60deg, 1,4-2" driver. Can be converted into synergy waveguide to save on drivers.
PM me for details.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 9th May 2019, 06:00 AM   #14
So is the SEOS 24 good down to 450hz even though it list 550 as cut off ? And are there any polar's for the SEOS 24 or 30 I cant seem to find them any where
Old 9th May 2019, 06:42 AM   #15
SubSoniks is offline SubSoniks  Wales
If the O/P's room dimensions are in feet then I would be more concerned about their hearing distorting and failing than the BMS.
Old 9th May 2019, 02:41 PM   #16
InOtIn is offline InOtIn
How come the RCF HF950 can have a lower cutoff than that of 400Hz at half the size of the SEOS-24? What’s the catch?
Old 9th May 2019, 04:22 PM   #17
ErnieM is offline ErnieM  United States
True. More concerned about the AE drivers being in public control. People getting carried away with sustained bass.
Old 9th May 2019, 08:35 PM   #18
Yes thats feet and will even be little smaller than that with treatment
Old 9th May 2019, 08:36 PM   #19
I dont understand that either K-horn is much smaller also and can go lower. They seem to be longer though.
Old 9th May 2019, 08:38 PM   #20
I am not that worried about the AE drivers if the BMS is good
Horn Lens for BMS 4594HEHide this!Advertise here!
Double 10 BMS 4594HE B&C 10NDL64 Cnyg PA Systems 5 14th January 2018 06:43 PM
FS - Altec 604-8G Horn Lens (original) vt4c Swap Meet 0 10th May 2017 02:20 AM
Dual 16 ohm BC 12ndl76 +BMS 4594HE 1.4" exit coax sine143 Multi-Way 9 31st March 2017 09:35 PM
JBL HL92 Horn / Lens Assemble TomHinton Swap Meet 0 5th January 2015 01:35 AM
DIY horn lens? ViolenceOnTheRadio Multi-Way 3 3rd October 2010 11:15 AM
Copyright ©1999-2019 diyAudio
