Old 9th May 2019, 02:34 AM   #11
mayhem13 is offline mayhem13  United States
This is the waveguide I’m considering
Eminence WG10 1" High Frequency Waveguide 70x60 2-Bolt
Old 9th May 2019, 01:28 PM   #12
erkki1 is offline erkki1  Germany
Celestion CDX1-1730 (CDX1-1731 for screw fitting).
People at Diy Sound Group & Hificircuit forums regard this high.
Titan-615LX official design info thread | HiFiCircuit
Old 9th May 2019, 09:09 PM   #13
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
Beyma CP380 has to worth consideration. I went to mine from scanspeak revelator domes and wasn't disappointed.
Old 9th May 2019, 10:28 PM   #14
MAAC0 is offline MAAC0  Portugal
I use Selenium and Eighteensound Drivers on my PA speakers and like them
Old 10th May 2019, 02:40 AM   #15
LineSource is offline LineSource  United States
LineSource's Avatar
COST NO OBJECT: I would use the $200 BMS 4552nd CD. Smooth with great detailed sound. If you get a LARGE horn, you can use this CD down to 1kHz.
BEST VALUE: I would use the $63 Peerless DFM-2544R00-08 CD. Plastic-coated Ti-diaphragm. Proven simple passive crossovers available.
I OWN: Faital HF108 and BMS 4552nd...both purchased used$
It would be SWELL if a modest cost ABS construction version of the SEOS-18 and SEOS-24 waveguides were available.
The ABS construction SEOS-15 waveguide which diysoundgroup sells for $38 would be my first choice for a 1200-1300Hz crossover to a 10" or 12" midbass.
I own: The $13 PartsExpress B-52 PHRN-1014 1" Horn is 10" x 14" waveguide with 5" depth which can support a 1.2kHz crossover between the midrange and tweeter horn. Several curvelinear cone 12" midwoofers will polar match 90-degrees @1.2kHz. The $130 Eminence DeltaPro 12A is a low cost high quality choice, with a 6.22" total depth which puts the voice coil near the 5.2" horn depth. Alternate Midrange: $188 the Eminence KappaLite 3012HO has natural sound; I own: $230 Faital 12PR300 has a ~5.0-5.2" voice coil depth.
Old 10th May 2019, 03:46 AM   #16
ScottG is offline ScottG  United States
Peerless by Tymphany DFM-2535R00-08 Compression Driver | audioXpress
perspective is everything
Old 10th May 2019, 06:12 PM   #17
Bergfinn is offline Bergfinn  Norway
TAD2001 from 1,5 khz to 9 kHz in 18Sound XT1086.Click the image to open in full size.
Old 18th May 2019, 04:50 AM   #18
vt4c is offline vt4c
My favourite - TAD2001
Old 19th May 2019, 05:47 PM   #19
norman bates is offline norman bates  United States
norman bates's Avatar
Mayhem,
That horn seems nice and rounded off at the horn mouth.
70 degree dispersion seems tight, but looks fairly conical otherwise.
It should sound good, maybe 2khz crossover point to me but i estimate, not measure.
Old 21st May 2019, 07:05 PM   #20
Hylle is offline Hylle  Denmark
Linesource and other who have Faital or 18Sound 1" compressiondrivers, I would like to know. Are they meassuring like there datasheets som of them like Faital HF108 does not have (much) impedance peak like most 1 " compressiondrivers between 1-2KHz? and is this influenced a lot by the used horn? (normally there is two impedance peaks, but the secound one seems to be suppressed on some drivers)
Tweeter/HF Suggestions for 2.5kHz-, 60-90° dumptruck Multi-Way 6 1st June 2015 05:13 AM
Cult movies - what is your favorite - what is your favorite part Ken L The Lounge 247 9th December 2013 02:32 AM
5KHz passive crossover ruijorgemoreno Multi-Way 12 16th November 2009 07:12 AM
Tweeter for 1.5kHz audiobomber Multi-Way 8 12th May 2005 03:38 PM
SS97's at 1.5Khz 5th element Multi-Way 5 19th February 2004 04:22 PM
Copyright ©1999-2019 diyAudio
