1st time try- TQWT -Beta 10CX
Old 9th May 2019, 01:11 AM   #11
GM is offline GM  United States
GM's Avatar
Originally Posted by 1hiep0 View Post
Thank GM I am lost at this would you explain?
Hmm, not sure how to make it simpler; I mean once the basic inputs are done the rest of the design, fine tuning, etc., is all done/saved in the Wizard.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th May 2019, 06:38 AM   #12
freddi is offline freddi  United States
freddi's Avatar
with hornresp - first do a calculation. Select Acoustical Power -then under "Tools" find "Output" and click on "Combined" - that opens up a utility where one enters the distance between cone center and ~vent center. THEN - go back to the Input screen to select the Loudspeaker Wizard to check effects .
Old 9th May 2019, 05:12 PM   #13
GM's Avatar
??? Why bother when you can do it the LW while watching it in real time?
GM
Old 9th May 2019, 06:03 PM   #14
1hiep0 is offline 1hiep0  United States
Originally Posted by freddi View Post
psd2013 should be very nice - I'd like to see he network some time but don't have that driver.
Thank freddi, I certainly will post the X-over as progress.
That look better, would you mind posting the hornresp input screen?
The idea is to have the coax center at the ear height as possible.
I started out the sim using Brian's sheet as stated in the original post and import to hornresp….still learning!.
Old 9th May 2019, 08:01 PM   #15
freddi's Avatar
GM - its obvious I'm not adept at HR. How does one quickly manipulate the "Acoustic Path Between Outputs" feature within LW?
1hiep0 - - here's the input I used - not sure of the path between the driver and vent centers
Old 10th May 2019, 06:14 AM   #16
David McBean is offline David McBean  Australia
What did I do wrong?
For one thing, the Cms value of 3.70E-01 m/N is not correct :-).
Cms = 0.37 mm/N = 3.70E-04 m/N
www.hornresp.net
Old 10th May 2019, 06:36 AM   #17
Originally Posted by chris661 View Post
I thought the "Path Length" was the difference in distance between driver and port to the listener.
In Hornresp, the acoustic path length is the length of the shortest acoustic path between the two outputs (assumed to be point sources). In the design being considered it is the distance between the centre of the direct radiator and the centre of the horn mouth.
Path length = 92.2 + 2.6 + 37.9 = 132.7 cm
www.hornresp.net
Old 10th May 2019, 06:38 AM   #18
www.hornresp.net
Old 18th June 2019, 03:43 PM   #19
Originally Posted by GM View Post
...so go into the 'chamber' window and add [92.2+2.6+37.9]/2 = 66.35 cm in the 'path' field to sum the two at the LP.
GM
Which path length is it L12, L23..? I don't understand.
Old 18th June 2019, 04:04 PM   #20
Default fixed
Fix, thank Dave
1st time try- TQWT -Beta 10CXHide this!Advertise here!
Eminence Beta 10CX (ZMA/FRD) Michael Chua Multi-Way 77 20th January 2016 09:40 AM
WANTED: Single or Pair of Eminence Beta 10cx tuxedocivic Swap Meet 0 16th April 2014 06:10 PM
ADS L620 CONVERSION TO EMINENCE BETA 10CX REFLEX DESIGN pianolydia Multi-Way 2 7th October 2013 01:20 AM
Eninence Beta 10cx Stage Monitor? naquat PA Systems 2 22nd August 2013 01:40 AM
anyone here work up a good crossover for new Beta 10CX? freddi Multi-Way 4 9th January 2010 04:41 PM
Copyright ©1999-2019 diyAudio
