DIY Clones of commercial speakers
Old 8th February 2020, 11:20 PM   #31
ChrisABC is offline ChrisABC  Canada
Auris Poison 1 clone of Boenicke W5.
Poison 1 | Products | Auris
Clone of Auris Poison 3
Auris Audio Poison 3 – HiFi Knights
Auris Clone
Old 13th February 2020, 01:34 AM   #32
Auris Poison 3 for post#31
from above Auris Poison 3,"Design-The unorthodox appearance comes from the narrow front baffle with a single fullrange driver (sourced from Fountek) placed close to the top of the speaker, bass woofer (from Peerless) placed on the side but also in the upper half of the baffle, and a tiny tweeter (from Tang Band) placed on the rear. The woofer works up to 300Hz where Fountek takes over up to 17kHz and the tweeter on the rear works from 7kHz to 22kHz. The crossover, as you can see on one of the photos, features high quality components sourced from Mundorf...."
Auris 3 diy clone the crossover looks like (from Speaker Terminals)
Highs 3.3 ohm Res, 2.2 uf Cap, .12 mH Coil, 1.5 uf Cap to tweeter TangBand 13-1761s 3rd order butterworth.
Mid 3.3 ohm Res, .12 mH Coil to Fountek FE85 1st order butterworth.
Bass 2.5mH Coil, 2.2 ufd Cap to Tang band W5-1138smf 2nd order
See the photos of the crossover,
Auris Clone
(or search Jeff Bagby's "Quark" Speaker Fountek FE83 disc, substitute FE85, Dayton ND20FA 6 tweeter and Voxel Sub TangBand W5 1138 Paul Carmody) - no rear ambience tweeter.
Old 17th February 2020, 06:42 PM   #33
for post#32
"Bass 2.5mH Coil, 2.2 ufd Cap to Tang band W5-1138smf 2nd order"
should be 22 ufd on Bass
Old 26th March 2020, 07:10 PM   #34
Audio Solutions Euphony
MTM
Scan Speak Discovery D2604-830000
Peerless SDS-134 THP - 830656
AudioSolutions - Euphony 90 | Gearogs Database & Marketplace
[2-drone] Audio Solutions Euphony 90 Clone
try Google Translate
This could work in the same box,
Iron Driver Overall Best Sounding Speaker: Design Details -
Techtalk Speaker Building, Audio, Video Discussion Forum
DIY Clones of commercial speakersHide this!Advertise here!
Should I do this or just buy commercial speakers? Navyblue Full Range 59 28th June 2018 11:35 AM
speakers for sale watt puppy clones mp006ltk Swap Meet 0 9th November 2007 12:55 AM
DIY Speakers FS 2.5 clones, Solist dshortt9 Swap Meet 2 2nd August 2007 02:38 AM
new commercial speakers then_dude Multi-Way 2 22nd July 2006 11:22 PM
How would you compare your DIY speakers to commercial speakers? AJ Bertelson Multi-Way 20 28th May 2004 03:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
