KEF LS50 playground - measurements of raw drivers in factory cabinets and simulations
Old 19th May 2019, 01:27 PM   #51
Zvu is offline Zvu  Serbia
Zvu's Avatar
double post
Tesla
Old 19th May 2019, 02:42 PM   #52
Tournesol is offline Tournesol  Belgium
Tournesol's Avatar
Originally Posted by Zvu View Post
Measurement 0, 12.5 and 25 degrees off axis of LS50W. Hardly any peaking of tweeter and very consistant set of curves. Quite maches my measurements of modified LS50.
Attachment 757618
I think you either have faulty product (in which case you should replace it) or you are trolling. So, what is it ?
Can you measure frequency response - 50cm distance is enough for gate to be set at around 3ms so we can see if there is a real problem. Given that you are sound engineer, mic and sound card shouldn't be a problem.
About speakers, I will never look at response curve to get an idea about how they sound. So many speakers with quite similar response curve that sound day and night. See what I mean ?
No, not a question of the sources themselve. I used many DACS, many devices in comparison (my main system, headphones, car sound system, PC. etc.) to try to understand my problems with those speakers. It makes a difference in micro dynamic, never on the tonal balance. All my other speakers are quite balanced. NOT those Kef.
And don't believe it is auto suggestion, oer any preconception against this brand: I worked with Raymond Cook and had a lot of confidence with the Kef products a a preconception: A total surprise.
Not to forget i was very excited about their innovating coaxial speaker, one of the reason i had spend my money blind on those speakers.
Yours faithfully,
Tryphon Tournesol
Old 19th May 2019, 02:54 PM   #53
Tournesol's Avatar
Originally Posted by maty tinman View Post
[How to Install and Use 7zip on Ubuntu Linux
i do use 7zip, but under windows. Usually working fine.
Yours faithfully,
Tryphon Tournesol
Old 19th May 2019, 07:07 PM   #54
XMechanik is offline XMechanik  Poland
XMechanik's crossover looks pretty good. Great job Mr X.
Attachment 757295
Thanks Zvu.
Great that it turned out that the tweeter filter also works well with coils DCRs more typical for air coils. Later I noticed that in my schematic I have DCRs generated for core coils, and these should be rather avoided in the tweeter circuit.
Adding a cap in parallel to the woofer coil is a good idea, it gains over a dozen of dBs attenuation of the breakup frequency (I would possibly consider adding a small resistor in series with the cap to avoid shorting for HF)
XMachina page thread
Old 19th May 2019, 07:46 PM   #55
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
troelsgravesen.dk Coils for loudspeakers
Tweeters
Most often we have a single coil in parallel with the tweeter, e.g. 2nd and 3rd order filters, and anything from 0.2-0.5 ohms usually goes goes well here. However, these coils are usually small and getting 0.15-0.30 ohms coils is no problem. I suggest coils wound from 0.5-0.8 mm wire.
"Comment is free, but facts are sacred" - C. P. Scott *** 40 years of the Spanish Constitution, My musical celebration
Old 20th May 2019, 04:46 AM   #56
Zvu's Avatar
No shorting up to 50kHz. First thing a crossover must be is to be safe. Here's impedance:
Though i had to add a resistor in that place for my Kef R300 crossover. Impedance was about 3 ohm at 20kHz but lower after that. 5 ohms if i remember. It was 2.7uF capacitor with purpose to kill the 2kHz resonance of woofer.
Tesla
Old 20th May 2019, 07:41 PM   #57
Tournesol's Avatar
This guy seems to have the same faulty product !
YouTube
I can hear the exact same defects even across my PC speakers.
Yours faithfully,
Tryphon Tournesol
Old 21st May 2019, 03:46 PM   #58
Maybe it interests some:
YouTube Review ! KEF Q100 vs Q150 !
PS: my modded Q100 sounded better first and much better after my last mod, Summer 2018.
KEF LS50 playground - measurements of raw drivers in factory cabinets and simulationsHide this!Advertise here!
Kef R300 playground - measurements of raw drivers Zvu Multi-Way 55 18th February 2019 09:56 AM
THAM 15, Simulations, Measurements & Comparisons lhaines Subwoofers 5 21st September 2018 04:50 PM
True Anechoic Kef LS50 measurements.. Remlab Multi-Way 66 21st September 2014 04:46 PM
Kef LS50, Gallo Speakers, brightness and measurements? zenpmd Multi-Way 16 2nd October 2013 04:25 PM
Factory T/S specs or DIY measurements? Help! majerjack Multi-Way 26 18th May 2012 09:42 AM
Copyright ©1999-2019 diyAudio
