KEF LS50 playground - measurements of raw drivers in factory cabinets and simulations
Old 14th May 2019, 08:31 PM   #31
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by maty tinman View Post
@Zvu
Off topic or not
I am so satisfied with the current sound of my modified KEF Q100 that I am afraid to modify the filter.......
The logic improves, to be in another larger room, would be two subwoofers cut at 110 Hz, I think.
A wise man told me once - I can only show you the door. You're the one that has to walk through it.
I'd also expect improvement by correctly adding few subs, but i's also deprive the Q100 of frequencies bellow that.
And don't worry about the off topic, i don't mind
Tesla
Old 14th May 2019, 08:36 PM   #32
Zvu's Avatar
Originally Posted by XMechanik View Post
This crossover was actually designed using XMachina software. It is shown in XSim because I usually try to modify selected results in an external (more handy) circuit editor. (This time I made only one change, 2 coils in series were replaced with a single coil with appropriate L & dcr).
That's actually pretty cool.
Is there an option in Xsim that can show Rdc of coils shown in schematic ? I'd simulate your crossover and make it a pic as i did with mine and with Goran's, if that's ok with you ?
Once again, great stuff your software is. I'll have the opportunity to try it very soon.
Tesla
Old 15th May 2019, 10:31 PM   #33
XMechanik is offline XMechanik  Poland
No problem of course. Fell free to process or modify. And thanks for sharing the measurements!
The DCRs of the coils are on the schematic (blue labels). I've put them manually, I don’t know a way display DCRs directly but maybe it is because I'm working with an old version of XSim.
XMachina page thread
Old 17th May 2019, 04:38 PM   #34
Tournesol is offline Tournesol  Belgium
Tournesol's Avatar
After the read of a lot of unanimous laudatory comments about those speakers, interested by the original design of this coaxial speaker, I decided to buy a LS50 wireless speaker set.
What was my surprise to see how the rendering of these speakers was caricatural. Fantastic trebles, awful high mediums (everything is aggressive and thin), inconsistent basses.
And this is all the more annoying as the high-end spectrum is detailed, precise, dynamic in an exceptional way.
The abrupt fractionation of the bass HP's membrane is probably responsible of this coloration that transform a piano to an harpsichord and a snare drum to a tambourin, and I do not understand why it was not filtered with steeper slopes, which should be so easy with the integrated DSP.
I'm hesitating between reselling or shelling them to add a passive plug to see if it improves things.
Another unbearable thing is that the directivity connection between the two speakers is so bad that simply changing the listening position vertically changes the tonal rendering in a huge way and that, changing the room of listen, we do not recognize the same speaker.
Yours faithfully,
Tryphon Tournesol
Old 17th May 2019, 04:59 PM   #35
Zvu's Avatar
LS50 definitely isn't a loudspeaker for everyone. No loudspeaker is. You obviously need a different set of compromises in a loudspeaker. I listened both LS50 and LS50W. Wireless is much better but it isn't worth the cash in my opinion. It is just too expensive for what it does. Even regular LS50 is too expensive.THIS loudspeaker costs 1000$/pair and LS50 is around 1500. Go figure.
Tesla
Old 17th May 2019, 05:09 PM   #36
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
When I first heard my KEF Q100 I was very disappointed. I thought about returning them! They sounded garish, without bass. After a very long burnin, of about two hundred hours, the sound was very different.
I think the fault is the speaker suspension, which is extremely rigid.
Frank Sinatra is playing right now and the sound is marvellous.
Frank Sinatra - September of My Years (1965), Vinyl, stereo, 2015, Universal, Holland
Now Playing + What are you listening to?
"Comment is free, but facts are sacred" - C. P. Scott *** 40 years of the Spanish Constitution, My musical celebration
Old 17th May 2019, 06:12 PM   #37
Zvu's Avatar
XMechanik's crossover looks pretty good. Great job Mr X.
Tesla
Old 18th May 2019, 03:13 PM   #38
Tournesol's Avatar
I wonder if there is some impedance curve measurements of the two speakers independently somewhere ?
And a question: Is-it possible to open and close the LS50 wireless enclosures without leaving any tracks ?
Yours faithfully,
Tryphon Tournesol
Old 18th May 2019, 06:02 PM   #39
Zvu's Avatar
Stereophile and SoundStage are independent so you can trust their impedance plots.
There is no way to open LS50 without leaving a trace. There are rubber plugs, four of them, on the back. They are glued so when removing them, and you must remove them to get to the bolts that hold front baffle, they conveniently disintegrate. Plugs have printed something like -LS50 anniversary- or similar so there is no point in replacing it.
EDIT: now i see that you wrote -wireless-. Try and tell us how it went.
Tesla
Old 18th May 2019, 06:41 PM   #40
Tournesol's Avatar
I have not fond any, only impedance curves of the complete enclosure (IE other side of the passive filter). That don't tell e lot.
I'm not very hot on this. So disappointed by those speakers. I hesitate between reselling or trying to voice them,
Yours faithfully,
Tryphon Tournesol
KEF LS50 playground - measurements of raw drivers in factory cabinets and simulationsHide this!Advertise here!
Kef R300 playground - measurements of raw drivers Zvu Multi-Way 55 18th February 2019 09:56 AM
THAM 15, Simulations, Measurements & Comparisons lhaines Subwoofers 5 21st September 2018 04:50 PM
True Anechoic Kef LS50 measurements.. Remlab Multi-Way 66 21st September 2014 04:46 PM
Kef LS50, Gallo Speakers, brightness and measurements? zenpmd Multi-Way 16 2nd October 2013 04:25 PM
Factory T/S specs or DIY measurements? Help! majerjack Multi-Way 26 18th May 2012 09:42 AM
Copyright ©1999-2019 diyAudio
