JBL L110 new cabinets
Old 26th April 2019, 04:05 PM   #21
phivates is offline phivates  United States
You brace for two main issues: acoustic pressure in the box, whether vented or not, and vibration transmitted from the driver to the enclosure. MDF is thought to have energy storage issues which need addressing on panels as large as yours, so going to the trouble of correct bracing is part of improving the original.
Old 27th April 2019, 08:59 AM   #22
mainframe99 is offline mainframe99
So due to my router having an offset square base, I had to make two new round bases for the previously mentioned driver rebating method to work;
And it wasn't millimeter perfect/press fit, but its close enough for me;
Next time I do this I will buy a router with a round base. When I bought the one I have, there were no trim routers available with round bases.
Old 27th April 2019, 10:39 AM   #23
6thplanet is offline 6thplanet  United States
6thplanet's Avatar
Are you going to flush the woofer in too? If your not planning to, please reconsider as it'll look alot better in the finished product. Truste me on this, you'll be happy you did it.
Old 28th April 2019, 11:30 PM   #24
Have now finished the fronts and started looking at bracing;
Old 29th April 2019, 01:02 AM   #25
Nice work on the recesses.
Old 30th April 2019, 01:56 AM   #26
6thplanet's Avatar
Yes, definitely, your knocking it out.
Old 30th April 2019, 08:22 AM   #27
Cabinets ready to sand and veneer. Quite pleased with how theyve turned out, but definitely feel ive room to improve on my next speakers. Im hooked! This is fun.
Old 30th April 2019, 10:54 AM   #28
6thplanet's Avatar
If you have a round over router bit, you might want run it around the outside of the port opening. Helps airflow in and out of the port, also looks better.
Old 30th April 2019, 11:00 AM   #29
I had considered that but then the veneer would be hard to finish to the round over.
Old 30th April 2019, 01:29 PM   #30
6thplanet's Avatar
Veneer it, use 2"tape and cover all around the port, router it, then the port perimeter will be taped off and allow you to paint the port black.
JBL L110 new cabinetsHide this!Advertise here!
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 12 12th July 2015 08:39 PM
old cabinets smak Multi-Way 7 30th August 2011 03:25 PM
Prices on Pensil cabinets and microtower cabinets TWills Planet 10 hifi 9 31st January 2011 02:21 AM
What to do with these cabinets? TurboFC3S Multi-Way 31 22nd October 2006 02:19 AM
Copyright ©1999-2019 diyAudio
