Dayton DS315-8 12" woofer box
Old 21st May 2019, 01:13 AM   #31
ICG is online now ICG  Germany
ICG's Avatar
Originally Posted by albertli View Post
I have been doing bi-amp for couple years but wish to make it simple.
I'm sorry to say that but if bi-amping complicates things for you, you're obviously doing it wrong.
I had a Déjà Moo - I've seen that BS before!
Old 21st May 2019, 03:01 AM   #32
albertli is offline albertli  Canada
albertli's Avatar
Please kindly tell me what is wrong with the idea of simply things. I like the sound of all my SE amps but don't want to run them through eq, active, crossover and with two/three power amps. To my ears, distortion is higher that way. I like my SE amp direct to a single full range driver, but still can't find the driver which can cover the whole sound spectrum.
Old Yesterday, 10:50 PM   #33
ICG's Avatar
What are you talking about? I was talking about bi-amping.
Like I said, if the distortion rises at bi- or tri-amping, you're doing something wrong. By tearing up the crossover at the wrong part, creating an impedance minimum or extreme phase shift your amp(s) may actually distort more. That could ie. be a impedance compensation which only works with a certain other crossover part before it or a notch filter or similar. That's not a general bi-amp problem though but one of either your amp, amp/speaker combination or incorrectly done bi-amp connection. It can even be a ground loop or phase problem, it can also mean your preamp doesn't like to 'feed' several power amps because the output/input impedance.
If you are talking about an active speaker, distortion can be caused by a crappy design of the xo or preamp in any part of the chain, a defect, mismatch of the input/output impedance of the pre-/amps or a wrong gain structure. Opposing to a wide spread misconception, the gain and maximum input voltage are often misunderstood. If you over-drive any stage, you can't get that distortion out of the system anymore. Distortion can ofcourse also be the result of a really off setting on a DSP or active crossover, like too low/high highpass/lowpass filters, too low filter order, too high filter order or too much/wrong EQ-ing.
That's not a general problem of active systems or DSPs, it's up to you to use it correctly.
That depends on your expectations. There are many viable options or none at all, just depending on what expectations and marks to reach you're demand to be fulfilled. There are surely a lot of combinations of speaker size/frequency range/dispersion pattern/max spl/efficiency/price/interaction with your listening room/your signal chain that can't do that. I can't tell you anything about that without knowing what you're expecting.
Old Yesterday, 11:12 PM   #34
albertli's Avatar
Thanks so much for your detail explanation /advices. What I want to tell you is there is nothing wrong with my eq and or bi-amping. Everything goes fin, sounds good and works well but I just wish if I could simplify thing with whatever available with me and make it simple. I like the sound from all my SE amps. That is all. No offence of any kind.
Dayton DS315-8 12" woofer boxHide this!Advertise here!
OB speakers using 8" woofer+3" dayton ps95-08 coherenceaudio Multi-Way 22 10th September 2015 07:55 AM
Dayton Audio DS315-8 12" woofer WhiteRhino Multi-Way 6 11th June 2014 09:16 PM
Dayton 10" woofer project dzkh63 Multi-Way 1 23rd June 2013 12:12 AM
dayton 4" woofer tyler477 Full Range 2 18th September 2008 03:17 AM
Dayton 295-305 (6.5" Woofer) problems? jsd Multi-Way 5 27th June 2004 02:21 PM
Copyright ©1999-2019 diyAudio
