Best contact cement available in UK?
Old 15th April 2019, 05:59 PM   #11
5th element is offline 5th element  United Kingdom
5th element's Avatar
I've used Evostick myself and it didn't seem as strong as the thixofix stuff. Although the Evo has been through formula changes over the years so who knows if what you buy today is the same as what I used.
Changes were apparently made to reduce emissions and with it bond strength suffered. I'd imagine you can't really go wrong with either.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 15th April 2019, 10:04 PM   #12
StewartH83 is offline StewartH83  England
Send a message via MSN to StewartH83
I had great success on a pair of DIY curved loudspeakers using Titebond veneer glue and vacuum bagging removing the air from the bag. Rapid dry time too 😊
Old 16th April 2019, 02:42 AM   #13
bentoronto is offline bentoronto  Canada
Have your rubber roller ready to tighten the connection, maybe also a rubber mallet.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (also, see recent post with data on a 17-foot labyrinth sub)
Old 16th April 2019, 06:49 AM   #14
lordy101 is offline lordy101
B.
Thanks, got a j roller on order. Waiting on a delivery of paper backed walnut veneer now.
Old 16th April 2019, 07:48 AM   #15
Mario Pankov is offline Mario Pankov  Europe
I would stay away of contact cement (PVA-based). It has a few issues for veneering:
1. It sometimes manages to penetrate the veneer and come up to the surface
2. If you have small gaps or uneven surface the bond will be weak
3. Can react with veneers that contain tannins - like oak veneer for example - creating black/grey spots
4. Is harder to work with (veneering only) compared to polychloroprene glues
I have tried many and hide glue and polychloroprene based ones (Henkel Moment Classic) a.k.a. shoe glue works best for veneering. For joints of the wood panels - PVA all the way unless you have slight gaps, then a polyurethane glue might be better suited as it expands a little.
Best contact cement available in UK?Hide this!Advertise here!
Contact cement -- wood and steel vladimirb0b Construction Tips 2 1st June 2017 10:57 PM
I thought contact cement would be stronger sbrunkow Construction Tips 19 16th April 2014 02:32 PM
cement resisters reddish75 Solid State 7 3rd March 2008 07:59 AM
Cement horn Ruben Multi-Way 31 2nd January 2007 04:35 PM
Copyright ©1999-2019 diyAudio
