Xover to add super-tweeter in a 3 way loudspeaker
Old 14th April 2019, 05:57 PM   #1
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Default Xover to add super-tweeter in a 3 way loudspeaker
Xover to add super-tweeter in a 3 way loudspeaker, I have laying around a couple of Focal TC120TDX2 that I want to use as super tweeter in my current 3 way system. Need help for suggestions what frequency to cross them, attached xover used in the current 3 way loudspeaker & Focal datasheet.
FR two loudspeakers smoothing 1/3
[IMG]Click the image to open in full size.
IR two loudspeakers
What about using a xover at 15kHz 2nd order 12dB/octave 3dB slope @ fx?
Old 18th April 2019, 08:17 PM   #2
No suggestions about the xover?
Old 19th April 2019, 06:59 AM   #3
PeteMcK is offline PeteMcK
single cap , 10Khz, refine from there
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 19th April 2019, 07:55 AM   #4
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Unless it's positioned in the very nearby, it will be barely audible. That's why the usual supertweeters are high sens/High eff. with L-pad or transformer/autoformer.
Try to position a waveguide ( it can be made with a cone of a dead speaker ) on the tweeter and see how it gains. For Fc=10 kHz its diameter being 344/10000=3,4 cm WL
Everything under and above heaven is in utter chaos
mare monstrum
Old 19th April 2019, 07:58 AM   #5
Another view on the seas design : a) resistor in series b) a lowpass?
mare monstrum
Old 19th April 2019, 10:33 AM   #6
Thank you I will try. Slope 3 or 6dB?
Between the attenuation resistor R1 and the tweeter is a filter for time delay alignment
Old 19th April 2019, 12:16 PM   #7
nipper1 is offline nipper1  United States
Here's what I have done in the past. I have plenty of capacitors and inductors in my parts boxes which obviously helps! Get a variable L-Pad and some inexpensive capacitors and a few inductors. Calculate L and C values for X/O's at say 8 KHz, 10 KHz and 12 KHz for starters. Do this for 1st order and second order X/O both. Pick a place to start; usually the highest frequency first and do listening tests using a capacitor only (1st order). Start adding capacitors in parallel, these can be low value like 0.22 uF, 0.33 uF, 0.47 uF, etc. one at a time while doing listening tests. If you get to the point where you think the tweeter is adding too much output, try an inductor for 2nd order. I use alligator clip leads to quickly allow connecting and disconnecting capacitors and inductors. Also, tweeter polarity may be an issue depending on what X/O freq. and slope you end up with. You can use a DPDT switch to quickly reverse polarity. It helps if you have a partner do these things for you while you sit in your "normal" listening position. Based on my hearing loss and others; I would also say to start at about 12 KHz, then 10 KHz, etc. If I were to guess, you will probably end up with 2nd order, 12 KHz, reverse polarity; with little to no L-Pad attenuation. Regardless of what others may say or think; it has helped "ME" get the most out of the top octave by experimenting in this way. Once you have this all fine tuned to "YOUR" personal taste and listening preference; replace the adjustable L-Pad with high quality fixed resistors and the caps. and coils with a higher quality as well. Of course, if you have access to test and measurement equipment, calibrated microphones, etc. you can do these experiments in a much more scientifically correct manner. In my case it doesn't matter; what I need is top octave boost based on listening tests that match "MY" hearing loss. Again, everyone's tastes are different, everyone's hearing loss is different; do not be afraid to experiment.
Old 19th April 2019, 12:44 PM   #8
Pano is offline Pano  United States
Pano's Avatar
Just a note. If you resize your images to no larger than 1200 pixels wide, they fit better on the page. 1900 (yours) is really too wide for browser windows.
Old 19th April 2019, 01:47 PM   #9
Thanks for the idea about how to setup.
Do you know how to resize?
Old 19th April 2019, 02:31 PM   #10
Now Pano?
Xover to add super-tweeter in a 3 way loudspeakerHide this!Advertise here!
Proac Super Tablette Xover fred0823 Multi-Way 0 28th February 2019 03:50 PM
Super CHEAP diy 2 way loudspeaker --- ! basslover911 Multi-Way 6 4th February 2010 01:37 PM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 06:52 PM
Using same xover for different tweeter? andy2 Multi-Way 31 15th January 2007 02:47 PM
Copyright ©1999-2019 diyAudio
