BLH midrange... Crazy?
Old 15th April 2019, 11:57 AM   #11
AllenB is offline AllenB  Australia
I'd like to comment here but I can't work out where to start. I'll just say that I probably wouldn't choose this way, but there might be other applications I'd sooner use a back loaded horn than here.
Old 15th April 2019, 10:42 PM   #12
pelanj is offline pelanj  Czech Republic
And why not front loaded? When the horn is getting small enough, I would go for front loading, efficiency gain must be the same or am I wrong?
Old 16th April 2019, 06:03 AM   #13
GM is offline GM  United States
GM's Avatar
Originally Posted by Phenoholic Anonymus View Post
Thanks for the reality check, i know it's a stretch and could sound horrible. Sometimes i get to enthousiastic with the simulation program: 150 - 1.200 Hz + 100dB with smaller drivers .
You're welcome!
Hmm, [150*1200]^0.5 = 424.264 Hz Fc
~13560"/pi/424.264 = ~10.17" effective diameter = 12" frame, not all that small.
If you base it solely on 1200 Hz, then it can be a 5-5.5", but it will need to be stronger, more powerful, longer, so better to use a relatively high Qt driver in a WG to shorten it as much as practical.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
BLH midrange... Crazy?Hide this!Advertise here!
Am I crazy? TundraLTD Subwoofers 10 24th July 2010 01:40 AM
Going Crazy(er) rkernell Analogue Source 1 19th April 2009 11:48 PM
I'm going crazy, please help, Pic's Bensen Solid State 28 16th September 2004 05:11 PM
Is this crazy? dc Multi-Way 25 20th October 2002 07:29 PM
Copyright ©1999-2019 diyAudio
