High excursion aluminium diaphragm woofer with inverted surround.
Old 9th April 2019, 07:37 AM   #1
Windforce85 is offline Windforce85  Poland
Default High excursion aluminium diaphragm woofer with inverted surround.
I am looking for high excursion aluminium diaphragm woofers with inverted surround to efficiently reproduce low frequencies in small volume. I'm not looking for woofers with other diaphragm material or surround taller than basket.
Peerless SBS160F35AL model is not available for retail purchase.
Any other ideas?
Old 9th April 2019, 08:46 AM   #2
HiFiCompass is offline HiFiCompass  Ukraine
Maybe this:
Accuton AS168-9-470 | HiFiCompass
Aluminium, inverted surround...
Old 9th April 2019, 09:20 AM   #3
I forgot to mention that price should be lower than for a kidney.
Old 9th April 2019, 10:25 AM   #4
marco_gea is offline marco_gea  Italy
Default The seldom spoken truth is...
...that air volume displacement (Vd = Sd x Xmax) is NOT the only thing that matters.
All else being equal
, a (large-Sd, low-Xmax) woofer will ALWAYS sound better than a (smaller-Sd, larger-Xmax) one.
Also, because of Boyle's law and the air's asymmetrical reaction to compression vs. expansion, achieving the same air volume displacement with a larger box volume is ALWAYS beneficial in terms of reduced distortion. Which, ceteris paribus, means that a (low Mms, high efficiency) woofer will ALWAYS be better than a (higher Mms, lower efficiency) one.
Fads come and go, but the laws of Physics don't change...
Old 9th April 2019, 10:40 AM   #5
Keeping this thread on merit is appreciated. This is just engineering choice which has been taken. I am already familiar with physics, thanks.
Old 9th April 2019, 12:06 PM   #6
Ugg10 is offline Ugg10  United Kingdom
Assuming this is the speaker you are looking at -
https://www.tymphany.com/drivers/dri...eet.php?id=703
Closest I can come up with are -
Hivi/Swan M6A - but this has a traditional rubber surround and slightly less Xmax - Product information:M6a Bass-Midrange
Monocor SPH-170 - this seems to have the inverted seal but only a small xmax (+-3mm) an a more traditional cone - SPH-170
The Tang Band W6-623I and W6-658I have a double roll seal but are more conventional cones and are paper/PP - W6-658I - 6.5" PPM. Woofer - TB SPEAKER CO., LTD.
A couple of options but none fit the bill I don't think.
Edit - how about this - bit more expensive but a 6.5" subwoofer with large xmax - Imagine I6SW-v2 6.5" Subwoofer - 12v Electronics
Old 9th April 2019, 12:14 PM   #7
CharlieLaub is offline CharlieLaub  United States
I do not think you will find such a driver in the "hi-fi" category. High excursion, low Vas drivers will likely use the traditional "outward" roll surround.
You might try to look at low-profile subs that are intended for car use. For example, Dayton Audio has that flat cone 10" sub:
Dayton Audio LS10-44 10" Low Profile Subwoofer Dual 4 Ohm
I has a sort of "multi roll" surround that is inverted next to the cone but then has another outward roll next to the frame. Not sure what "high excursion" means to you but Xmax=10mm.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 9th April 2019, 01:53 PM   #8
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
6 mm excursion
Aurum Cantus AC-180F1 7" Woofer
also with dual VC
Aurum Cantus AC-180F1D 7" DVC Woofer
Everything under and above heaven is in utter chaos
mare monstrum
Old 9th April 2019, 08:24 PM   #9
Charlie, not only in the "hi-fi" but also everywhere else, I'm near certain it is not possible to find such a driver, unfortunately. But maybe there is small driver manufacturer doing such or smth like that, maybe someone here knows it and point me to it.
Old 9th April 2019, 08:38 PM   #10
ollieimpossible is offline ollieimpossible  Canada
closest match that I can think of.... SB Acoustics SW26DAC76-4 Shallow 10" Subwoofer 4 ohm
High excursion aluminium diaphragm woofer with inverted surround.Hide this!Advertise here!
Passive Radiator for Low Excursion, Low Displacement & High Sens Woofer? goody75 Subwoofers 15 7th May 2012 08:07 PM
6.5 Woofer aluminium cone 4 ohm lduarte1973 Multi-Way 2 3rd February 2012 08:03 AM
Any drawbacks to using ferrofluid in a low-excursion woofer? 454Casull Multi-Way 7 9th December 2006 03:40 PM
where to buy 8" high excursion sub in EU ? wingman Subwoofers 25 12th June 2004 10:18 PM
High Excursion 8 Inch Woofer. Is Their Such A Beast? OMNIFEX Multi-Way 26 21st December 2003 03:22 AM
Copyright ©1999-2019 diyAudio
