KEF Q500 new crossover
Old 17th April 2019, 03:01 PM   #61
wtnsmk is offline wtnsmk  United Kingdom
At least finally I could measure with 4.2ms gate:
freq3 - Google Drive
The issue was the speaker was too close to the ground. With this measurement the speaker is from 120cm from the ground.
Old 17th April 2019, 06:18 PM   #62
Zvu is offline Zvu  Serbia
Zvu's Avatar
Try to set this offsets just for test:
For tweeter all offsets are 0
For midrange there is only Z offset and it is -11mm
For woofer we have Y offset of -300mm and Z offset at -50mm
All of this is just for test purposes and aren't real offsets.
Offsets are entered with microphone as a reference point.
Now, since you haven't used ARTA, you have to derive Z offsets yourself. If microphone was pointed to the tweeter, all offsets for it are 0. Since you have concentric driver for mid-hi you only have to derive the Z offset for midrange and since i have LS50 which is almost the same as your concentric it is safe to say that Z offset for your midrange is around -11mm (as is with mine concentric driver). For woofer, based on your cabinet and driver placement sketch, woofer is 30cm below microphone position so we have X offset 0 and Y offset is -300mm.
To derive acoustic Z offsets for drivers you have to place the mic on axis to the tweeter at 1m distance. Don't touch the volume of the amplifier (or any other volume control in chain for that matter) and set start frequency of the sweep at 300Hz. Measure the tweeter and name it say Q500TW. Then you connect the midrange in parallel with the tweeter and make another sweep. Name it Q500MID.TW. Then you set start frequency of the sweep at 20Hz. Disconnect tweeter and measure just midrange. Name it Q500MID. Then connect the woofer in parallel to the mid and make another sweep, you get it, name it Q500MID.WF. Then disconnect the midrange and measure the woofer, name it Q500WF.
Now you have everything that is necessary to derive Z acoustic offsets yourself.
Set listening distance in VituixCAD at 1m. Make the tweeter in sim and upload the tweeter Q500TW and impedance. Then make a midrange in sim, and import Q500MID file. Import Q500MID.TW file as Reference (that's what it's called in LspCAD that i use) and compare it to the combined curve. Add Z offset in mm until they overlap. Then disconnect the tweeter and make a woofer in sim and upload Q500WF and impedance. Now upload as a Reference Q500MID.WF and compare it to combined curve. Set X offset at 300mm and add Z offset (usually negative value) until the curves overlap. Now connect the tweeter again and you can begin to simulate your crossover.
Old 17th April 2019, 07:08 PM   #63
Thanks I will do these measurements.
The weird thing, in Xsim, I'm already really close to the measured response (brown measured, black simulated), if I DON'T invert the mid speaker...:
Old 17th April 2019, 07:27 PM   #64
Zvu's Avatar
I'd, again, advise you to use Holmimpulse or Arta. I'm not sure that rew is good for modeling frequency response. It has few different types of smoothing that all give slightly different results. I'm not saying that's bad but it takes knowledge to know when and what to use. With Holm and Arta it is much simpler.
As for differences in Xsim, maybe it is optimized to work with rew measurements like Vituix is for ARTA.
Old 17th April 2019, 09:53 PM   #65
I'm doing the measurement in HOLMImpulse and I can't change the freq range. There is a start freq in device & signal, but if I put that up to 3-400Hz my measurement is just completely useless. I see some crazy curve. Also which sign I should use? Log or chirp? They look different in the low range
Old 17th April 2019, 10:15 PM   #66
Looks like this:
Old 17th April 2019, 10:48 PM   #67
Zvu's Avatar
Red Spade Audio: How to measure your crossover with Holm Impulse
Old 18th April 2019, 11:08 AM   #68
Thanks for the link, it was really useful, but unfortunately doesn't understand my questions.
These are my tweeter responses if I start the measurement from 400Hz:
Old 18th April 2019, 11:18 AM   #69
Could you please have a look on the file? Maybe it just a problem with my visualisation...
holmimpulse - Google Drive
Thank you very much!
Old 18th April 2019, 01:18 PM   #70
Ok I think I found the issue, I tried to change the start freq on the first (device & signal) tab rather than the highpass on the measurement tab... really confusing
Here are the measurements:
correct.zip: holmimpulse - Google Drive
you will see these measurements:
LF - woofer
LF MF - woofer with midrange (normal polarity) - 20-20
LF MF 2 - woofer with midrange (reversed polarity) - 20-20
MF - midrange - 20-20
MF HF - midrange + tweeter (reversed polarity) - 300-20
MF HF 2 - midrange + tweeter (normal polarity) - 300 - 20
HF - tweeter - 300-20
KEF Q500 new crossoverHide this!Advertise here!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Tfive PC Based 321 7th June 2019 05:52 PM
KEF Q500 Crossover upgrade rdsu Multi-Way 14 12th October 2017 03:39 PM
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Copyright ©1999-2019 diyAudio
