B&C DCX464
B&C DCX464
Old 14th August 2019, 06:50 AM   #81
phase_accurate is offline phase_accurate
Cool - which waveguide do you want to use with them ?
Charles
Old 14th August 2019, 07:38 AM   #82
daemonsgr is offline daemonsgr  United Kingdom
Any idea on "basic" crossovers for this?
Old 14th August 2019, 11:11 AM   #83
Ale55andr082 is offline Ale55andr082
Hi, a pair of questions, if I may:
-this coax CD have some shorting ring? the datasheet say nothing about it
-there is some horn (from B&C or other brand) that on pair with DCX464 can produce a similar curve like that one showed on the datasheet? Even a curve that roll on around 7-800Hz might be ok...
thanks in advance (..and sorry for my bad english :/)
Old 15th August 2019, 03:04 AM   #84
rotgg is offline rotgg  United States
Charles
Will be using a new customers waveguide
Old 19th August 2019, 04:17 PM   #85
Bennett Prescott is offline Bennett Prescott  United States
Bennett Prescott's Avatar
B&C DCX464
Originally Posted by Ale55andr082 View Post
  • this coax CD have some shorting ring? the datasheet say nothing about it
  • there is some horn (from B&C or other brand) that on pair with DCX464 can produce a similar curve like that one showed on the datasheet? Even a curve that roll on around 7-800Hz might be ok...
Hey Alessandro,
The coax uses a copper cap on the HF section only, we found no benefit to using any shorting device on the MF section. Regarding the horn, I am unaware of any off the shelf horn that can go to 300Hz. We use two large horns in testing and measurement at B&C, the one used for the data sheet is attached.
Bennett Prescott, Sales & Operations Director
B&C Speakers NA bprescott@bcspeakers.com
Old Yesterday, 04:04 AM   #86
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by Bennett Prescott View Post
Hey Alessandro,
B&C needs a more aggressive and more powerful marketing team.... for speaker motors, a copper cap is GOLDEN BABY!
I remember in the "Mad Men" TV series the marketing team was able to sell cigarettes by using the phrase "It's toasted" to describe the tobacco
Personally, I now think less of the DCX464 sound quality. Go figure.
Old Yesterday, 04:50 AM   #87
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I've built plenty of 2-ways and 3-ways without a copper cap or shorting ring on the midrange, because it wasn't worth the expense.
For instance, if I'm crossing over from a smaller midrange to a tweeter, I don't need a shorting ring because I'm just not playing the midrange very high.
I imagine B&C used a similar decision process in their design.
If you're trying to get a 12" or a 15" to play up to 2khz, it makes sense, but for a 5" or a 6", it's less compelling.
Old Yesterday, 06:16 AM   #88
And even here it is not the diameter of the driver itself that makes the difference regarding the shorting ring - it is the diameter of the voice-coil (which is usually larger on larger drivers) that results in a higher voice-coil inductance.
Charles
Old Yesterday, 09:37 AM   #89
Sorry, this mean better quality or worse? Cant get what you mean in your last line.
Old Yesterday, 11:49 AM   #90
300Z is offline 300Z  Brazil
Send a message via AIM to 300Z Send a message via MSN to 300Z
And to expand on this, a neo magnet will inherently have lower inductance than a ferrite magnet system. A copper cap simply may not be needed in the application.
B&C DCX464Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
