Broken wire on a coil, any way to fix it ?
Old 20th March 2019, 02:31 PM   #21
dadafu is offline dadafu
Yes continuity is good
possibly overdriven (900W RMS Amp, subwoofer 450W RMS and 900W Max) but the coil is dark when new too, as you can see on the joined pic, so I'm not sure about it
Tried to add some tin on the original solder, but the new tin doesn't go in the old one
Old 20th March 2019, 06:08 PM   #22
Galu is offline Galu  Scotland
Did you do as I suggested?
What do you mean by 'tin'? Use a tin and lead flux cored solder.
FE3T mentioned the possibility of the voice coil being aluminium and aluminium/copper joints are notoriously difficult to solder.
Do you know if the voice coil is copper or aluminium?
Old 20th March 2019, 06:14 PM   #23
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Before trying the speaker again try to find out why it blew in the first place or you could end up blowing it again !
Maybe amp is putting out DC ?
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 20th March 2019, 06:28 PM   #24
For interested parties, soldering aluminium is discussed in this diyAudio thread:
Soldering Aluminium
Broken wire on a coil, any way to fix it ?Hide this!Advertise here!
Locating point of broken wire in cable diy didi Solid State 7 9th April 2015 04:21 PM
broken coil back Digital Line Level 3 23rd November 2014 09:30 PM
Broken transformer wire.. Biggie1494 Power Supplies 7 14th March 2013 10:56 AM
Broken cartridge/blue wire nathanjh13 Analogue Source 0 5th December 2010 01:46 PM
Using a coil of Wire and A Voltmeter to Mea PHilgeman Equipment & Tools 5 5th April 2007 12:56 AM
Copyright ©1999-2019 diyAudio
