Adding tweeter to full range speaker super high ohm resistor needed?
Old 15th March 2019, 08:37 PM   #21
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by Galu View Post
P.S. When using the calculator enter just one tenth of your amplifier power, as that's the maximum which will reach the tweeter via its 12db/octave high pass filter.
This calculator is a bit simpler to use than the Weber one.
LPad Driver Attenuation Circuit Designer Calculator
I guess the tweeter will survive even if connected with no crossover at all, since amplifier driving this contraption is:
a 3W bluetooth chip amp
nor there is danger of having the tweeter fall out at such high power since:
just superglued then hot glued in place
and in any case Math tells me that a 75 ohm resistor in series with a 4 ohm speaker produces an attenuation of 25.5dB ... I guess that tweeter will survive anything that 3W amp can throw at it.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 15th March 2019, 08:51 PM   #22
Galu is offline Galu  Scotland
Thanks JM!
realflow100 also says that the crossover circuit (12dB/octave) is sealed inside the housing of the tweeter so he would not be able to insert an L-pad between the crossover and tweeter anyway!
@ realflow100 - like you said, just go on using the tweeter as you have set it up.
Old 15th March 2019, 09:13 PM   #23
realflow100 is offline realflow100  United States
Ok! and yeah i tried it with my class D 2x50W amp hooked to 12v 2A power supply and the speaker bottoms out from too much bass if I turn it up past like around 11 oclock position on the volume knob on certain songs and I dont want break the speaker since it sounds decent.
so sticking to the 3W bluetooth chip amp it is! it gets close to bottoming out on max volume but the amp limits the power so it doesnt bottom out. runs off 5v USB with a 18650 3300mAh panasonic cell so it should last a long time on battery power. it is the loudest while plugged into USB though. but only by a few dB
Old 15th March 2019, 09:16 PM   #24
Great bit of DIYing you're up to there - enjoy!
Old 16th March 2019, 02:53 PM   #26
Originally Posted by kokoriantz View Post
Similar one
That one says "With Only 2.8V, 9.7dB of Pure Sound" - I think they mean 97dB!
Old 16th March 2019, 04:02 PM   #27
lmao spamming tags in the title of the listing. why is that a thing still?
Old 19th March 2019, 01:38 AM   #28
I hooked a 5v 2.5A power supply to the input where the battery would for for the bluetooth module. now its a bit too powerful. if I turn the volume up too loud. on some songs the bass hits at just the right frequency and the speaker it came with bottoms out. (even with a modified smaller deeper tuned port to help reduce the boomyness and make it sound cleaner.
but the amp chip is barely skin temperature. It doesnt feel hot at all.
theres a lot less distortion too at high volume. more bass too.
it actually powers my MK402 bookshelf speakers quite surprisingly well now too. it actually gets them flexing a bit at the low frequencies!
Old 19th March 2019, 03:15 AM   #29
JMFahey's Avatar
Well, thatīs a lie and you know it.
Like when you said you powered a car amplifier with a 9V battery and it worked fine.
Old 19th March 2019, 06:13 PM   #30
its not a lie.
and the car amplifier cut off at 7v for some reason it has a really low cutoff voltage. i was using a beefy rechargeable 9v NIMH battery rated like 300mAh
and it works fine. I just plugged 5v 2.5A power supply for a USB powered hub into where the battery would go and it seems to be a lot more powerful now with less distortion compared to just using battery power.
the amplifier chip (its mono since the speaker it was in only had one speaker) barely gets warm even at max volume
Adding tweeter to full range speaker super high ohm resistor needed?Hide this!Advertise here!
Adding a tweeter to full range gaust Full Range 53 25th July 2017 11:40 PM
Adding a super tweeter to a full range portreathbeach Multi-Way 112 25th July 2017 06:31 AM
Looking for advice on adding a super tweeter to high efficiency mono speaker Josephjcole Multi-Way 54 3rd June 2017 02:23 AM
Adding Tweeter to Full Range ttan98 Full Range 95 24th October 2011 08:46 AM
Copyright ©1999-2019 diyAudio
