Max distance woofer and midrange
Old 15th March 2019, 06:03 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by planet10 View Post
it is easy to do the trigonometry.
True, but I asked about audibility, are there any tests you know of?
Actually, is it easy?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th March 2019, 08:04 PM   #12
HammerSandwich is offline HammerSandwich
Originally Posted by Korppi View Post
I want to do a setup which allows tweeter&midrange to be ear level while sitting at the sofa, but that midrange&tweeter combo can be lifted up fastly to the ear level while listening standing up.
Why not adjust the TM module's angle instead? You could then aim the highs at your ears without significantly affecting the MW spacing.
Rice-Kellogg 2020!
Old 15th March 2019, 10:47 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
All depends on the genetic hearing acuity, care of hearng and how well trained you are. Many people will not even notice but it will drive more than a few away (ie a segment of those are going to have choosen FR drivers because the whole question becomes a non-issue).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th March 2019, 12:40 PM   #14
From the psychoacoustic tests of audibility of comb filtering that Toole has done the take away also seems to be that it's not much of an issue.
Old 16th March 2019, 05:09 PM   #15
frugal-phile(tm)
planet10's Avatar
The issue of woofer to mid or mid to tweeter is about way more than comb filtering.
dave
Old 16th March 2019, 05:43 PM   #16
Maybe someone can tell me what they are, I'm a bit bored with guessing games
Max distance woofer and midrangeHide this!Advertise here!
Hornresp 2 Driver Tapped Horn Woofer Location? Distance? Do It Yourself Subwoofers 11 26th March 2015 11:39 PM
Large distance between Tweeter and Bass-Midrange like Avalon Eclipse-which advantages tiefbassuebertr Multi-Way 10 23rd August 2012 02:37 PM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 06:17 PM
dipole midrange or subwoofer, distance with wall ? mbon Multi-Way 34 2nd August 2004 06:26 AM
Distance between Woofer and Midrange driver LageB Multi-Way 9 21st August 2003 05:53 AM
Copyright ©1999-2019 diyAudio
