Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 13th June 2019, 11:24 AM   #921
Ro808 is offline Ro808  Netherlands
Simply put: if you want wider coverage (at least on plane) than roughly 60°, for a given throat size, horn length and shape, you'll need some sort of pinching/narrowing in the horn path in order to 'shape' the wavefront (and avoid beaming).
Old 13th June 2019, 11:51 AM   #922
Mind the intentional use of the word "horn".
Old 13th June 2019, 12:05 PM   #923
Some may argue, "what about this?"
A (blue) horn and no pinching to speak of.
Old 13th June 2019, 12:09 PM   #924
Look again:
Old 13th June 2019, 12:15 PM   #925
Should be: "at least in one plane"
Old 13th June 2019, 12:33 PM   #926
phase_accurate is online now phase_accurate
I wonder wether the smoother oval diffraction slot of the 18s has less disadvantages then the ones on horns like all those RCF HF9... or the JBL flat-front biradials.
And I also wonder what the radiation of the Meyer one looks like.
Charles
Old 13th June 2019, 12:41 PM   #927
For a long time I've wondered what the throat area of the K402 looks like.
Old 13th June 2019, 12:45 PM   #928
Here it is, thanks to member PK.
Some call this "a dirty throat".
Old 13th June 2019, 12:52 PM   #929
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Inside RCF HF940 throat (ignore the rope)))
flesh flash flush
Old 13th June 2019, 12:55 PM   #930
Charles
Approximately like this:
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
