Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way? Please consider donating to help us continue to serve you.
Old 25th May 2019, 06:50 AM   #621
camplo is offline camplo
Is that a product that I could purchase?
Old 25th May 2019, 07:51 AM   #622
Ro808 is offline Ro808  Netherlands
No, but you could make/print these or similar horns. This horn has a full rollback, but it's possible to 'cut' IT at 90. This would result in some diffraction and reflectance though.
Old 25th May 2019, 08:54 AM   #623
silverprout is offline silverprout  France
silverprout's Avatar
Originally Posted by badman View Post
There's a lot going on there, I wasn't trying to write the book on driver design for midrange vs. woofers and subs
Not necessarily having much impact on midrange viability- case in point, the shorting sleeve solution accomplishes both improvement to thermal performance as well as better midrange viability.
I'm on the train of thought of my design and therefore intensely biased... it is not easy to damp a extremely large membrane on a powerfull motor where there is no place for a shorting sleeve, but IMHO it is more a technical design choice than a vital element.
Things I Should Have Learned In School (But Probably Didn't)
Old 25th May 2019, 05:59 PM   #624
I think you took the right train (of thought), silversprout
Old 25th May 2019, 08:25 PM   #625
Your remark opens the field of philosophy, so i will do what i can and stay far away of any dogmatism because there is no good desing
Old 26th May 2019, 01:25 AM   #626
Are you still building/experimenting? We had some exchange of thoughts last year, if I remember correctly. You showed a paper mache horn ao.
For your intimite listening space, I would opt for an efficient 12 or 15" with horn or AMT from 60-80Hz and up, complemented with 2 smaller (active) subs.
You might want to look for some older B&C's like the 12 PE 32, 12 PH 32, 12 PL 32 (or equivalent drivers from other brands) which are perfect for such a setup.
At night you could switch off the subs, in order to listen without disturbing the neighbours
Old 26th May 2019, 03:08 AM   #627
I can't believe the only source of horns is Poland...like, seriously?
I did find this 2" to 1.5" or 2"Throat Horn Flare Bolt On 10" x 18" For Assorted Bolt On Drivers | eBay
a version of another horn recommended in this thread that has some kind of 1.5-2" adapter.
Old 26th May 2019, 05:49 AM   #628
That's the horn also known as the ZXPC 10x18, available at this store for 10 bucks less.
They also sell the 11x17, a Selenium/JBL clone with somewhat narrower dispersion (contrary to the specified 90x40), but pretty good nonetheless.
The 10x18 is also sold by PRV Audio and available at PE.
Old 26th May 2019, 06:09 AM   #629
If you want to buy horns (and perhaps build your own later):
For a 1.5" throat... I would probably stick with JBL, join the 'diffraction club' and buy these...
Or the horns that Mitch owns.
PS, PM sent.
Old 26th May 2019, 06:36 AM   #630
So diffraction slots are not a deal breaker? The jbl 2834 and m2 horn any good?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
