Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way? Please consider donating to help us continue to serve you.
Old Yesterday, 09:28 PM   #5471
camplo is offline camplo
4 18's would uncomplicated things but sacrifice of space. These enclosures aren't small lol.
I am really digging whats depicted in the picture. Could I take my TL design, Face the driver upwards, and fold the Terminus over the top of the driver? I'm not sure exactly what slot entails...I'm guess I could keep the terminus and still some how slot load the driver?
I need to find a different supplier then....
Old Yesterday, 10:28 PM   #5472
nc535 is offline nc535
Uncomplicating things is usually a really good idea. With 4 18's you get the performance of two 18s in a TL which is a complication. The TL is harder to build and it might not come out precisely as modeled.
Four 18's up front like I drew (mine are 15's) does indeed look impressive. I've done the drawings and built the woofers but I've never lifted the 2nd woofer on top of the stack out of fear for my back. I've found I'm satisfied with just the lower woofer working with subs out in the room.
I don't see why you couldn't add slot loading to the TL, but I think its an unnecessary complication. At the XO frequency being considered, CTC isn't an issue. It does minimize the height for a MTM stack but its not necessary to get a lobe free forward beam at the XO we are talking about.
If keeping things simple becomes your goal and 4 18's up front is within the realm of possibility, then consider side by side direct radiator woofers below the horn. I think the pair of 18" woofers will be a good match to the horn in both width and height for a better directivity match at XO. That can be made to work well aesthetically as it did for JBL back in the day.
Size shouldn't be an issue with sealed TD18s, definitely would be for bass reflex.
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old Today, 01:13 AM   #5473
Right now you've got me interested in slot loading the 15M in a sealed box. I don't know how to model this in hornresp though. What type of effect is the slot going to have on the FR.
Currently I am dedicated to the TL. I mean that if I build it and don't get it right, I will not give up until it is right, which is pretty much standard when building a TL thats never been built before.
CAn we talk about this....are you suuuure? How am I figuring this? I might have used xdir to confused myself but at 250hz from the center of the 15" to the center of the horn will be....18.5-20"...I am not talking about mtm though.
Old Today, 01:56 AM   #5474
A slot loaded woofer is modeled as an offset driver horn. A pure slot is such a horn with no expansion. But if you build it as I did as a very high aspect ratio conical horn it will play higher. You can see the HR model and the effect on the FR in post #3 of my Companion Woofer thread.
I agree with direct radiators you will get 20", about 500 mm, or less CTC. Here is what XDIR showed me
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?-slot-loaded-vs-direct-radiator-beamwidth-jpg
File Type: jpg slot loaded vs direct radiator beamwidth.jpg (132.1 KB, 39 views)
Old Today, 06:31 AM   #5475
GM is offline GM  United States
GM's Avatar
Originally Posted by camplo View Post
Do I need 4?
Based on all that I've read [not all], the 'tone' of your project eschews Synergy concept, so I meant multiple compression drivers on a combiner/phase plug attached to a suitable horn with one full range and three low passed to get the necessary extra power handling to get down to 150/whatever Hz you want/need to make a nominally two way system.
I just said [4], I haven't researched it; may need more to keep excursion at a < 1/2 power for high SQ. Otherwise Synergy concept, my preference for all things high SQ, till something better comes along of course.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
