Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way? Please consider donating to help us continue to serve you.
Old 7th December 2019, 02:26 PM   #4731
docali is offline docali  Germany
docali's Avatar
Originally Posted by camplo View Post
OK so this is a strange question to ask, but here we are lol! In one hand I have a TL enclosure with low efficiency but the impedance is lower than a normal sized TL...
In the other hand, a more efficient sealed box or a even more efficient ported box.
Either way power is fine. I'm wondering how does impedance play a role in thermal compression and if it make sense to build this inefficent TL for everything else it gains...
So far as I understand your current intention is to use a quite narrow radiating horn. IMHO the best combination with this is dipole LF part with it's radiation character like an 8. So, either an H-frame, U-frame, Y-frame dipole or something similar like WE 7331A which is lifted somewhat from the floor. I heard the WE 7331A in Munich at high end fair and was really really surprised how much bass substance it is able to reproduce. Even too much for some people.
Or as I already stated a front loaded woofer with an U-frame chamber at the back or even a straight Karlson tube at the back. Your compression driver need to be highly tamed in the MF region to have equal levels up to 10k-20k. So, you will not need such a high efficient LF part. A TL is a quite complex thing and you cannot calculate everything in advance because the stuffing is difficult. The sound of a bass reflex is not my cup of tea.
https://sphericalhorns.net
Old 8th December 2019, 02:04 AM   #4732
tnargs is offline tnargs  Australia
Originally Posted by ErnieM View Post
Another interesting driver I've been playing with is the Dayton PS65LP.
Dayton Audio PS65LP-4 6-1/2" Ultra Efficient Low Profile Full-Range Driver 4 Ohm
Very nice neutral detailed sound. Impressive off-axis performance as well.
The contradictions in the title of that link made me smile. First wince, then smile.
Old 8th December 2019, 02:13 AM   #4733
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
It can only meet it's sensitivity spec above 1KHz.
Don't Procrastinate....Just Do It!
Old 8th December 2019, 06:55 AM   #4734
Ro808 is offline Ro808  Netherlands
It's probably a decent driver, but those specs.....
Even 95dB would have been optimistic.
Old 8th December 2019, 07:51 AM   #4735
Width = 123cm, Height = 213cm.
Xo: 233Hz
Sensitivity: about 103dB
Old 8th December 2019, 07:58 AM   #4736
MkII (3 instead of 4 woofers and horn moved to the top).
Old 8th December 2019, 08:51 AM   #4737
Based on sims in hornresp?
A TL with a (considerably) lower efficiency than either a sealed or ported cab for the same driver is propably overstuffed.
Did you read the short thread I referred to a few days ago?
Impedance in itself doesn't affect thermal compression.
Thermal power compression is the result of the rise in voice coil resistance which accompanies coil heating due to inefficiency of power transfer.
Efficiency is always a good thing, but modern, less efficient (mostly subwoofer) drivers feature specific cooling solutions in their magnet structure.
The TH18+ isn't comparable to such airpumps.
Old 8th December 2019, 03:48 PM   #4738
camplo is offline camplo
Overdamped, gotcha.
I'm not an expert but I will look into the topic. I've started here Dipole vs Monopole woofer
Old 8th December 2019, 04:09 PM   #4739
docali's Avatar
Better look here with pictures:
Subwoofer Origami
The W-frame or Ripole is also very interesting if you have a low x-over.
Old 8th December 2019, 04:18 PM   #4740
Are there any benefits of being over damped? Would a compression driver diaphragm be considered highly damped in comparison to a dynamic woofer?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
