Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 3rd November 2019, 04:47 AM   #4031
camplo is offline camplo
I had my suspicions, thank you for clarifying, I’ll have to play with it more now that I understand better what I see. I was clearly confused, so thank you all
Old 3rd November 2019, 04:53 AM   #4032
David McBean is offline David McBean  Australia
Originally Posted by nc535 View Post
By convention, the driver is mounted at S2 on an OD horn or at S2 of an OD1 horn.
Just to clarify, the driver is mounted at S3 in an OD1 system.
www.hornresp.net
Old 3rd November 2019, 09:05 AM   #4033
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by camplo View Post
I had my suspicions, thank you for clarifying, Iíll have to play with it more now that I understand better what I see. I was clearly confused, so thank you all
I thought you were right
TL introduces mass loading to the cone...I don't know where's the transition from TL to ML-TL, but surely any acoustic load reflects what happens behind the cone.
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 3rd November 2019, 11:36 AM   #4034
nc535 is offline nc535
I'm too used to starting at zero
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 3rd November 2019, 11:51 AM   #4035
Traditionally the cross-sectional area at the throat end of a multiple-segment horn is designated as S1.
www.hornresp.net
Old 3rd November 2019, 11:54 AM   #4036
I know. It's the rest of the math and programming worlds that are different... Including Europe for numbering floors
Old 3rd November 2019, 04:11 PM   #4037
If the frequency response is correct, that’s what matters, the thing that makes no sense is that sound is only emitted from one source when there should be two in the wavefront sim. If you draw a Tm using your mouse, in the wavefront sim, everything looks correct, but now you can’t sim freq response. So within the loudspeaker wizard the driver is facing directly at the screen...in the wavefront editor the driver can only face up down left or right. That’s what’s being suggested.
Old 3rd November 2019, 08:04 PM   #4038
I ran the sims for bass reflex on horn resp and got different results, wonder which one to trust. With horn resp, the displacement increases drastically above about 40hz, where as with winisd displacement decreases above 40hz ion the same manner.....I'm thinking winisd is right.
Old 4th November 2019, 12:42 AM   #4039
I am pretty sure that you can trust Hornresp... :-).
www.hornresp.net
Old 4th November 2019, 02:12 AM   #4040
So if I set pmax to 0, the curve looks right, then as soon as I add more power to the signal, 1 in this instance, the response changes to what you see in pink....make that make sense. The blue is reflective what I see in WinISD.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
