Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 9th October 2019, 01:49 PM   #3581
Ro808 is offline Ro808  Netherlands
Interesting!
Lately, I've been looking into multicells and sectoral horns.
The Smith horn and derivates look good on paper, but I have my doubts about combination of vanes and the diffraction mouth.
If you want to optimize the Smith horn, you will probably get something similar to Joseph Crowe's Yuichi Radials> including roundovers by mouth.
Old 9th October 2019, 02:08 PM   #3582
phase_accurate is offline phase_accurate
Rob
Do you have any idea at what frequency the modern Augspurgers are crossed over ?
Charles
Old 9th October 2019, 02:14 PM   #3583
pelanj is offline pelanj  Czech Republic
There are some good looking Smith Horns for 1" drivers on Ebay from Moldova, I bookmarked them for later, when there is some spare cash, I will definitely get a pair. The links are for reference: Horn 350 Hz 1 inches | eBay and https://www.ebay.com/i/112193907513
Could anyone experienced have a look at the dimensions if these look right? Especially the 350 Hz seems slightly small - or do the dimensions sound right? They are ~352*609*61 mm for the larger horn and 500*280*64 mm for the smaller one.
Old 9th October 2019, 02:30 PM   #3584
Pano is offline Pano  United States
Pano's Avatar
I had the good luck to be able to A/B a system with 15 cell horns verses one with a Smith horn. Identical drivers top and bottom. The 15 cell was my preference - because it sounded more life-like to me - but some other listeners preferred the Smith. It was much better than I expected. However for a DIY horn, the Smith is going to be waaaay easier to build.
Take the Speaker Voltage Test!
Old 9th October 2019, 03:05 PM   #3585
Augspurger horns in the later monitors are actually more akin to radial horns. In the past, Augspurger (also used) the Westlake style Smith derivatives, which came with, and without vanes (for the smaller HF horns).
Augspurgers are completely DSP-ed these days, but the old ones are presumably crossed at 800Hz or even higher, which is still quite low considering the size of the horns.
Anyway, Augspurer's old constant voltage networks are quite complicated/ingenious.
Here's an AES comment paper, in which he also touches on the angled baffles.
File Type: pdf Augspurger-comments-constant-voltage.pdf (311.7 KB, 22 views)
Old 9th October 2019, 03:54 PM   #3586
BTW, George Augspurger is not actively involved with the current brand that bears his name.
Old 9th October 2019, 04:21 PM   #3587
Westlake Smith horns, check the chamfered mouth:
File Type: jpg Westlake Audio Speakers Studio Monitor TM-1 TAD JBL Drivers.jpg (345.1 KB, 208 views)
Old 9th October 2019, 04:46 PM   #3588
Augspurger Horn:
Old 9th October 2019, 04:56 PM   #3589
Pano's Avatar
It would be interesting to build and test the 3 versions of termination, all else being equal.
Smith, Westlake, Augspurger.
Old 9th October 2019, 05:47 PM   #3590
That would be interesting indeed. Heritage forum members have built and measured Smith and 9800 horns.
The 9800 is similar to Yuichi and other radial horns, without vanes but with a pinched throat.
There's something about vanes, cells and sectors.
Pano, which multicells do you use?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
